It is currently Sat Sep 26, 2026 5:57 am
Post Posted: Mon May 24, 2010 3:42 am
for some reason i turned my car on to clean out the radiator and engine left it running for like 30mins, i was then playing with my lights and so forth. For some reason if i flick my high beams on the temp gauge rises to the top of the yellow box just before the red section on my temp gauge. the little tab on my thermo stat is broken so it doesn't have the best contact but soon as i turned the lights off it dropped back to just below half way. any one have any idea why this would be is it something to do with the current of power making the gauge rise when i turn the lights on or is the car over heating?
thanks luke
Post Posted: Mon May 24, 2010 3:58 am
it could be an earth problem by the sounds of it...
P.S. i know nothing about sierra's & their magical ways... i'm sure someone older & wiser will chime in anytime... :wink:
Post Posted: Mon May 24, 2010 4:05 am
I had the same deal with mine, and as Gus says, it was an earth problem, get some welding earth lead, make a length to go from the battery to the body, no dramas.
Post Posted: Mon May 24, 2010 4:07 am
so whats not earthed properly if you dont mind me asking is it the battery or is the car itself not earthed properly would i be better off earthing the battery to my chasis?
Post Posted: Mon May 24, 2010 4:08 am
forgot to mention my earth for battery at the moment is bolted to my intake manifold its been there since i bought the car like it.
Post Posted: Mon May 24, 2010 4:11 am
The battery should be earthed to the body. The block should also be earthed. I would also be replacing your temp sender by the sounds of it.
I want my old sig back :(
Post Posted: Mon May 24, 2010 4:12 am
you cant earth a battery everything earths to it
what happens is there is too much resistance in your earth from body to battery, so when higher current items that are earthed to teh body (headlights) are on the voltage differential on the voltage regulator changes so it outputs higher and makes the gauge rise
your fuel gauge should rise too
New earth firewall to battery will fix it, chassis or block wont
Post Posted: Mon May 24, 2010 4:49 am
yeh ill be ordering new temp sender when permits. and ok thanks guys should i leave the earth running to the engine then get a 2nd line to go to the shell as well or just remove it from the manifold and bolt it to the shell? and the fuel gauge no longer rises it use to not any more :S
Post Posted: Mon May 24, 2010 4:51 am
im also guessing that will answer my question in the other thread of my head lights pulsing im guessing.
Post Posted: Mon May 24, 2010 4:53 am
Add a new line, leave the existing.
Post Posted: Mon May 24, 2010 4:58 am
alright ill have to get some line ill try get 0 gauge wire for it ill just put up with it not being right for now till then
Post Posted: Mon May 24, 2010 5:05 am
I have some heavy duty earth welding lead if you want some, cost of freight only, then you only need to get ends put on, I went to an electrical store, and bought a $3 end that I bolted to the body, the other just went into the battery terminal.
I used this for my starter motor lead as well, the skinny crap that was on it is nothing by comparison, and it spins so much faster now.
Post Posted: Mon May 24, 2010 6:34 am
With the Zook it is important that the body, chasis and engine are all grounded correctly. The Zook switches the ground unlike Aust and US cars.
Heavy duty lead works wonders and helps stop all those little electrical gremlins.
If in doubt power out!
Post Posted: Mon May 24, 2010 7:05 am
Nothing I can add that hasn't been mentioned already. However, if you're gonna need a new sender I'd suggest just getting an aftermarket gauge. It'll cost a bit more but will come with the sender.
Post Posted: Mon May 24, 2010 8:21 am
thanks for the offer suziblu when i get the cash ill shoot you a pm bit strapped at the moment but when i do ill pm you cheers. also ando zook im confused with The Zook switches the ground unlike Aust and US cars. makes no sense to me sorry. and glavas i will look into this a bit more as would be good, i just dont want a car full of gauges s i need another gauge for my fuel tank, so i may just start with a new sender they are only 15$ from supercrap. but i will start with adding a earth to my chasis and adding a earth to my shell that way i will have a earth on my shell engine and chasis does that sound right?
thanks for all your help guys
Post Posted: Wed May 26, 2010 8:41 pm
To give you a basic example of the differnet power switching as follows:
Ground Switching - The Switch is located on the ground side of the Load (Light etc). Asian Vehicles
Power Switching - The switch is located on the Power side of the load (Light etc). Aust and USA
Australian Standards for All electrical Equipment except for Asian Cars is to switch the power.
Post Posted: Wed May 26, 2010 10:28 pm
ok so what i get is that they turn on through the ground not power
Post Posted: Wed May 26, 2010 11:05 pm
Yes thats right Lukes_89, it make things a little more complicated but it all works in the end.
Post Posted: Thu May 27, 2010 2:06 am
that makes sense i understand now :) thanks heaps would it matter when i wire up my own things like i have wired up my electric fuel pump to run from positive and negative dosnt break ground?
Post Posted: Thu May 27, 2010 2:16 am
If you want some, Ill cut and send, pay when your flash again, if it gets you on the road reliably, its all good.
Post Posted: Thu May 27, 2010 2:42 am
pm sent champ
Post Posted: Thu May 27, 2010 2:44 am
My pleasure.
Users browsing this forum: No registered users and 61 guests
