Ok, now that everyone's had a good laugh at my last thread, I've managed to grind the bolt off, remove one leaf, replace the bolt and put it all back together.
I spun the wheels again, just thinking of the concept and noticed the diff center sounded like a 2 stroke motor... and the prop shaft seemed to "grip" for half a second every so often while i was spinning the wheels (maybe once every half a wheel spin or once per wheel spin)
Guessing it should be smooth, and somethings wrong with my center right?
Also noticed two of my drive shaft nuts have come off, I think i may not have aligned the teeth correctly after i replaced my uni joints. have to re-align that and get some nylock nuts (seeming spring washers didnt do a thing)
_________________ 1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Users browsing this forum: Google [Bot] and 105 guests
