It is currently Sun Oct 11, 2026 7:38 am
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Mon May 24, 2010 10:02 am
So should it end up looking like this?
Post Posted: Mon May 24, 2010 10:06 am
You got it, top to top & butt to butt. :oops:
Post Posted: Mon May 24, 2010 10:16 am
Sounds ideal
Post Posted: Mon May 24, 2010 10:17 am
Jimny's don't have a heater tap and normally should have coolant running through the heater core all the time, If its been blocked off a loop hasn't been established for the engines coolant to flow from and to the engines heater pipes, coolant may be not able to cool parts of the engine. that pipe at the bottom coming from the engine looks like its been blocked. Is this the case?
Post Posted: Mon May 24, 2010 10:22 am
I think it's folded over it's self, ineffective bypass.
Post Posted: Mon May 24, 2010 10:25 am
and looking on the Jimny workshop manual it shows coolant travels from the head via the heater core to the water pump. thus restricting coolant flow from the head. may be causing your issue.
Have you just bought the car? maybe this is why it was sold.
Post Posted: Mon May 24, 2010 11:02 am
Yep had it for a week.. slipped a disc yesterday, so as soon as I've been to the BackSnap doctor I'll be swapping those hoses around.
What dollars are you looking at for a heater core if it needs swapping out?
Peter
Post Posted: Mon May 24, 2010 1:05 pm
to see if this is the problem don't worry about the heatcore for now, just make sure coolant can flow from engine outlet to engine inlet and see if this helps the overheating.
the heater core is in the dash so I'd think the time to replace would out way the price of the core... I hope I'm wrong thou
Post Posted: Mon May 24, 2010 1:10 pm
That sounds like the go... cause after a quick search the reoccuring price i'm seeing is $330 for a new heater core.. and most of a day to change it over.
Post Posted: Mon May 24, 2010 1:39 pm
I have bypassed mine as my heater core under the dash leaks bad!
I am wanting to put the jimny core and aircon that i have in mine, so i has a new core! :D
Post Posted: Tue May 25, 2010 9:54 am
Guess who else has a leaky heater core!!! Just disconected the inlet/outlet for the heater core and funnel'd hot water into the top fitting.. got a bit of warmth through the vents, and a few dribbles on the floor in the cab. So it looks like I'll be fixing/replace that in the coming week.
Peter
Post Posted: Tue May 25, 2010 9:55 am
BlueSuzy, did you buy your AC & heater core new or from a wreck?
Post Posted: Tue May 25, 2010 11:31 am
Pull yours out 7 take it to a radiator shop, thay could either match it with another or passably fix yours.
Post Posted: Tue May 25, 2010 12:44 pm
I bought a whole car.. Look in my sigline..
Post Posted: Tue May 25, 2010 1:10 pm
ha ha never saw that
Post Posted: Tue May 25, 2010 1:14 pm
I am also keeping coils, diff spring/arm mounts and Aircon/heatercore system
Damn you bought a whole car just to get that.. lol
Peter
Post Posted: Tue May 25, 2010 1:55 pm
No. I bought the whole car cos it was cheap and profitable in 5 seconds after i bought it. :lol:
Maybe i will make the Jimny sig Red
Ah thats betterer. :lol:
Post Posted: Sat May 29, 2010 8:49 am
Damn thing...
Flushed the radiator today, undid the bolts that attach the top hose to the engine, as per the workshop manual.. And WWaaLLaaa
Thats not gonna fit.
Post Posted: Sat May 29, 2010 8:51 am
But the bottom hoses looks to go here??? Is that it?
Post Posted: Sat May 29, 2010 8:57 am
Yep, careful with the housing tho, it's just plastic.
was about to say wrong hole on the 1st pic's..
Post Posted: Sat May 29, 2010 9:01 am
How the hell are you supposed to get in there... lol... This is gonna be a 6 pack job I can see it right now.
Post Posted: Sat May 29, 2010 9:04 am
I think the manual your reading is for the g13bb and you have M13a engine. the flow chart for the cooling system is for the g13bb engine.
Post Posted: Sat May 29, 2010 9:06 am
You should see it in a swift!!!! 8O 8O
Just swing the alt out of the way.
Disconnect the batt 1st tho..
Post Posted: Sat May 29, 2010 9:18 am
That explains a lot!!
8O BBzzap :x :oops: :x :twisted: bang clang :roll: :roll: :wink: 8O :D
Post Posted: Sat May 29, 2010 9:22 am
If you do that I'll give you $20 for the eng & box. :P :lol: :lol: 8O
Post Posted: Sat May 29, 2010 10:00 am
hah haha
Post Posted: Sat May 29, 2010 10:01 am
You can keep the Ecu & harness, that would be melted to the carpet anyway.
Post Posted: Sat May 29, 2010 10:04 am
This should help
Post Posted: Sat May 29, 2010 10:07 am
That would be my style too..
On my FJ73, I wired 1 of the Spotlights backto front or something, with a bad relay.. cant quite remember.. But as soon as I turned the Spotties on all the Wires melted and a big cloud of smoke came out of the engine bay, it was a good thing I had my pocket knife on me, or I think I would have lost the whole car.
Post Posted: Sat May 29, 2010 10:17 am
That looks much better :wink:
The problem when smoke comes out is its really really hard to put it back in. :lol:
Users browsing this forum: Google [Bot] and 259 guests
