It is currently Tue Sep 08, 2026 11:14 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Tue Jul 17, 2007 4:44 pm
Sounds pretty bad but luckily I didn't plow the the front diff into a huge rock but rather bumped it into a tree stump while going over it backwards, only way out, was late for dinner too. So it just broke and moved from the mount. The bit that goes from the diff to the transfer case is rubbing against the bottom of the motor a bit but I think it's alright otherwise. Obviously I won't be 4wding untill it gets fixed, which could be a good thing. What model GV can I get a steel front diff from to replace this one and will it be expensive?
Thanks.
'94 Vitara: 2" lift, BFG 235/75R15 MT's.
Datsun 2
Post Posted: Tue Jul 17, 2007 4:54 pm
I think its 2000 on manual GV and all 2003 on GV's
expect around $1000+ to do it
Post Posted: Tue Jul 17, 2007 5:50 pm
All years of V6 manuals and late '03 auto V6's onwards and don't forget the same goes for XL-7's although their cross member mount is a little different so some modding is needed.
Putting too much load on it in reverse is what did it to yours. If you had a strap over it to allow it to be bolted down to the cross member on both sides instead of the single mount to one side as supplied by the Factory it may well not have broken.
Post Posted: Tue Jul 17, 2007 6:10 pm
Don't know much about GV's , is that steel or alloy and is it cast , Cheers Paul.
Post Posted: Tue Jul 17, 2007 6:24 pm
The steel front diffs are in the models I mentioned above. All others have the alloy housings with the exception of the diesel models in other markets.
Post Posted: Tue Jul 17, 2007 8:34 pm
shit ay? im getting mine done as we speak and the housing is only costing 250 plus freight
plus im getting new diffs (5.12) (remember i have a j20a) and the brakes done.
Suzuki's - It's not the size,
It's how you use th
Post Posted: Tue Jul 17, 2007 9:10 pm
ok thanks for that. Will there be any gearing issues?
Datsun 2
Post Posted: Tue Jul 17, 2007 9:22 pm
Also how would I go about getting one, and one that's decent? Thanks again.
Datsun 2
Post Posted: Tue Jul 17, 2007 11:54 pm
go to a suzuki supplier. the one im getting is brand new but i am just getting the housing. if you do this they will swap your gears in the diff into the new steel one.
It's how you use th
Post Posted: Wed Jul 18, 2007 12:30 am
which bit are you getting? the housing part the axles slide into or the carrier part that the gears go into and mitchy has broken?
when you get em post the part numbers up :)
Post Posted: Wed Jul 18, 2007 1:37 am
I'd like to know more about breaking front Diffs. Hopefully from others experiences, not my own!
So where Mitchy broke his (at the mount), is that where they usually bust or do they break elsewhere if you lift them?
Has anybody got pics of the modified stap mounting cj describes?
Would you be game to put a front locker in an aluminium housing that has the strap mount?
Thanks guys.
Rod W
92 Vitara JLX Wagon
Post Posted: Tue Sep 11, 2007 1:54 pm
So a local wreker has sourced a couple from NSW and Vic but they're asking for a ratio...what would that be?
Thanks again.
Datsun 2
Post Posted: Wed Sep 19, 2007 1:04 am
Anyone??? Do I need a specific diff ratio to swap a Vitara front diff with steel GV diff?
Thanks.
Datsun 2
Post Posted: Wed Sep 19, 2007 1:08 am
no cause youll have to put the guts from your diff into the steel part anyway
Post Posted: Wed Sep 19, 2007 1:50 am
Mitchy,
What sort of money for the steel diff housing have you been quoted to get them up from down south?
THis mod is on my todo list...
Rod W
92 Vitara JLX Wagon
Post Posted: Wed Sep 19, 2007 2:25 am
ahhhh ok thanks. Yeah they didn't give me a quote 'cos they were waiting on a reply from me, hopefully this'll all cost under $1k though. I'll update again later...
Datsun 2
Post Posted: Thu Sep 20, 2007 3:43 pm
Another question, I need to get the terminology right. A guy in NSW has a housing with the gearing pulled out of it. Would that be exactly what I'm looking for?
Thanks again.
Datsun 2
Post Posted: Thu Sep 20, 2007 5:29 pm
there is the housing which normally refers to the 'front' part that the axles normally slide into and the actual centre bolts into
then there is the carrier, which is the bit all the gears go into and normally snap
Post Posted: Thu Sep 20, 2007 11:40 pm
Right so the carrier would be the big alloy bit that I want to replace with a steel one.
Thanks again.
Datsun 2
Vehicle: 75 Cruiser
Post Posted: Thu Sep 20, 2007 11:46 pm
yer i think Bruce went through this drama with wreckers, they all have a different understanding as to what things are, and give prices on the wrong things.
Post Posted: Thu Sep 20, 2007 11:50 pm
really you want to replace both bits but the carrier is the part the gears are on and has the mount that bolts to the crossmember and snaps off
Post Posted: Fri Sep 21, 2007 12:59 am
hmmm ok well now I have a laymans and techical explanation, should be no worries, thanks.
Datsun 2
Post Posted: Fri Sep 28, 2007 3:04 pm
If anybody has swapped their R&P's into a steel housing, do you have a 4.3 R&P that came out of it kicking around that you don't want? If so PM me.
Post Posted: Fri Sep 28, 2007 4:51 pm
Thanks again.
So the carrier is the bit that sits inside the ring gear?
If that is right then power goes thru the following: pinion gear -> ring gear -> carrier -> axles -> wheels
Is that correct?
2002 SWB GV
Lifted and Locked
Post Posted: Fri Sep 28, 2007 5:19 pm
no thats the hemisphere
carrier is the part the pinion and hemisphere bolt to
Post Posted: Wed Oct 03, 2007 3:28 pm
Hmmm well they're asking for the diff ratio again, 4.3 for a manual is right? But the go is that the guts get swapped around anyway isn't it?
Thanks again.
Datsun 2
Post Posted: Wed Oct 03, 2007 3:31 pm
yeah dont worry about ratio, or get a 4.3 and help cj out :wink:
Post Posted: Wed Oct 03, 2007 9:13 pm
Mitchy, You only need the housing 'cos you will re-use your guts. See Pic.
They probably don't want to sell just the housing so you got to get the lot, spare guts included.
Rod W
92 Vitara JLX Wagon
Post Posted: Thu Oct 18, 2007 2:52 pm
Well the wreckers here have sourced one in Vic for about $900 all up, sounds very expensive, includes about $200 of freight. He's ordered both of these parts labeled in the pic and I think that's what he called them. Is that too expensive? I've asked for both parts since they're both alloy and both exposed...
Thanks again.
Datsun 2
Post Posted: Thu Oct 18, 2007 3:34 pm
8O That's not cheap at all. I wouldn't want to be paying more than about half of that. Who's that through?
Users browsing this forum: Google [Bot] and 78 guests
