It is currently Mon Oct 05, 2026 5:33 pm
Post Posted: Thu Jul 15, 2010 7:59 am
so at 4:30 AM 8O i went out to warm up the jimny and it no go.
i tryed to get it going and it wouldnt crank, just made a tick noise and then .... nothing. Had a play this evening and it finally started after i held my tongue out to the left whilst standing on my right foot and jiggled my wires a bit think it liked me touching it up. Could it have just been a bad earth? or do you think its a whole lot more sinister???
Post Posted: Thu Jul 15, 2010 8:19 am
What wires were you giggling? Sounds earthish
Post Posted: Thu Jul 15, 2010 8:30 am
there is a small wire and a bigger wire and some dry mud also called dirt on the end of the starter and not a lot of room in there so cant give you any more info than that (didnt get home till 6 ish and its a bit dark to see under there)
Post Posted: Thu Jul 15, 2010 8:36 am
Dirt isn't a good look mate. Give it a good clean, to the extent of taking it out and giving it a good blow out with a compressor, terminal cleaner on the terminals. Install and double check all connections are tight
Post Posted: Thu Jul 15, 2010 8:41 am
ok thanks for your help terminal cleaner ?? umm i take it i can just get this from super crap?
Vehicle: jimny
Post Posted: Thu Jul 15, 2010 8:59 am
just use some contact cleaner
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Jul 16, 2010 7:13 am
I had the same thing in my Sierra a few months ago. I had used so much degreaser under the car that there was no grime protecting the contacts and they corroded, I resurfaced them all with a file, then after bolting back up, sprayed on some silcon terminal protector to stop it happening again.
all good.
Vehicle: Sierra
Post Posted: Fri Jul 16, 2010 7:45 am
never heard of a stater motor, what is it? ..... :D
Post Posted: Fri Jul 16, 2010 1:24 pm
starter motor brushes?
Vehicle: '92 Sierra
Post Posted: Sat Jul 17, 2010 11:17 pm
Do jimnys have the same clicky starter issues that sierras do? Sounds a lot like that. In the sierras theres a fair bit of voltage drop on the wire that runs through the ignition switch to the starter. As a result its not enough juice to turn over the starter motor so it just clicks. The work around is to use a relay and take power straight from the battery. Search clicky starter. It's that common on sierras that there's pre-made wiring looms and suzi shops.
Users browsing this forum: Google [Bot] and 173 guests
