It is currently Tue Sep 08, 2026 11:47 pm
Post Posted: Tue Oct 30, 2007 12:59 am
I am going to do a Rear diff Oil check and need to know what I need to put back in...
I want to do a drain and refill..
So yeah what do I need???
Post Posted: Tue Oct 30, 2007 1:01 am
What ever the book tells ya. 75 / 90 would be ok.
Post Posted: Tue Oct 30, 2007 9:38 am
isnt the oil only 2 weeks old?
Post Posted: Tue Oct 30, 2007 12:05 pm
Yeah but Since I am going off road regularly and the diffs are going underwater alot... I thought a regular Oil change on the diff would have been the smart thing to do..
Post Posted: Tue Oct 30, 2007 12:27 pm
have a look at the top of the diff, you will see a hose that goes up above the fuel tank, that is the breather hose, it stops any water being sucked in to the diff, especially seeing you have new genuine seals either side on the axles
you have nothing to worry about, I would only be worried if you have the entire diff submerged for long periods
at best take the filler plug out of the back of the diff and stick your finger in, if its milky replace it, if its clear keep on plugging
Post Posted: Tue Oct 30, 2007 1:14 pm
Where does that breather pipe go to ?? I followed it but lost it above the fuel tank?
Checked the filler Plug.. still clear..
Post Posted: Tue Oct 30, 2007 1:27 pm
if its anything like a GV it goes up into the cabin next to the fuel filler
Post Posted: Wed Oct 31, 2007 7:58 pm
OUCH Just bought 4 litres of Castrol Transmission FLuid GL5/ 80/90
Cost $42.98
With NRMA Card Holder Discount $39.40
Then I found out that when my mechanic did the Car, he changed the Oils
I will need a new Diff plug as the old one is looking a tad naffed..
Oh well at least I have the oil to do it in the future lol...
Post Posted: Wed Oct 31, 2007 8:15 pm
if its not HYPOID diff oil dont even think of putting it in your diffs
Post Posted: Wed Oct 31, 2007 11:01 pm
That would be it... Hypoid... not sure what that means though
Users browsing this forum: No registered users and 70 guests
