It is currently Sat Nov 14, 2026 7:05 pm
Post Posted: Fri Nov 02, 2007 2:54 am
Just wondering if anyone has made their own extended shackles? I was thinking about having a go at making a set.
Vehicle: MY2019 Jimny
Post Posted: Sat Nov 03, 2007 2:55 am
It's not too hard, but often they don't really help much, and can make your ride worse.
I am no expert, but basically a 2 inch shackle extension will yield about 1 inch of lift. Longer springs are helpful too, as your shackle angle will change, suiting a longer spring a bit better.
I say go for it!!!
Post Posted: Sat Nov 03, 2007 4:47 am
A 'H' pattern shackle with a bit of 25x25 welded in the middle. Now I just run 50x10 flat bar with nothing in the middle very easy to make and really cheap
Post Posted: Sun Nov 04, 2007 6:31 pm
Thanks for the help guys
Post Posted: Sun Nov 04, 2007 8:18 pm
Just wondering what size (from bolt to bolt) you think I should make them? Thanks
Post Posted: Sun Nov 04, 2007 9:26 pm
50mm longer
Post Posted: Mon Nov 05, 2007 12:57 am
Standard is 70 so make it 120 centres
Users browsing this forum: No registered users and 82 guests
