It is currently Mon Sep 21, 2026 2:48 am
Post Posted: Fri Jul 23, 2010 9:54 pm
I always spend forever trying to find this, and the OL search is terrible, so i linked it here.
http://www.outerlimits4x4.com/viewtopic ... a&start=30
Vehicle: MY2019 Jimny
Post Posted: Fri Jul 23, 2010 10:23 pm
Good find, it is relevant to my interests.
Post Posted: Fri Jul 23, 2010 10:54 pm
ahhhhh.......prime example of why i never share anything on outers anymore.
too many garden gnome people.......
hang on.....theyre here now too....... 8O
Post Posted: Sat Jul 24, 2010 3:34 am
haha glad that helps linc.
yes, if anyone knows of any about i'de be keen to pay good money for it.. ever wrecker i've tried don't have any... but now i know you can get them from celica's and coronas it widens the search.... :D
Post Posted: Sat Jul 24, 2010 4:51 am
rocky road sell them new for 229 US plus 280 postage :o :o :(.. im contemplating this as well.
Post Posted: Sat Jul 24, 2010 5:42 am
Google Rocky Road before you buy from them, they arent known for their quality and reliability even in the states.
Post Posted: Sat Jul 24, 2010 6:09 am
ta for that... ill just keep wrecker hunting... might even buy a whole car just for it :S
Post Posted: Sat Jul 24, 2010 7:23 am
I brought the whole car out of the local bargen hunter when I did my cresida conversion. Got it for $100 I drove it on the car trailer. Id ring up all the small town wrecker as the city ones don't seem to want anything under 1997.
I couldn't even give the rest of the car to the wreckers it had a really nice 5K motor in it.
Post Posted: Sat Jul 24, 2010 7:52 am
That'd be great IF you want LEFT HAND DRIVE.... :roll:
Post Posted: Sat Jul 24, 2010 8:24 am
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
yes thats why america don't work for most steering stuff....
Post Posted: Sat Jul 24, 2010 9:03 am
i've got a 1 litre lwb box and the pitman arm seems different to the toyota one can this still be done. Great post by the way!
Post Posted: Sat Jul 24, 2010 10:19 am
wow, cool looking zook in your avatar is it yours?
also, i thought that all sierra box's (from 1L-1.3 and all the years) were the same. it would be probly just the same amount of work to fit it to a 1.3swb as a 1L lwb.... only speculation....
Post Posted: Sat Jul 24, 2010 11:35 am
yer :roll: wasnt thinkin hard enough bout that...
Post Posted: Fri Oct 01, 2010 12:48 am
I've mounted up my cressida box, it's as far forwards as i can get it, and one of the bolts line up, thats a good thing :D Now im onto the pitman arm, what have others used? And im running a mini ruf, wanted to make it a full ruf, but the cressida arm is the same lenght and has a pin in the end of it.... the axle still has about 18mm to come forward, and im just confused.... i researched, but came up with nothing concrete.....
so what pitman arm do i need to go and get? criteria is shorter, dropped slightly and a hole in the end?
Post Posted: Fri Oct 01, 2010 1:32 am
vitara pitman arm is straight and shorter and doesnt drop thou...
Post Posted: Fri Oct 01, 2010 1:44 am
and if it's cast ill not be able to press it, i might have to notch the chassis.... ill see if i can angle the box much....
Post Posted: Fri Oct 01, 2010 2:00 am
I have a straight vit arm if you need one. $20 + postage
I run the vit straight arm on my vit ps in my swb. Stock draglink. Taper is in arm.
Post Posted: Fri Oct 01, 2010 2:24 am
when you set one of these up try to angle the box so you get a good line with the shaft from the wheel and rag joint, don't be too worried about the pitman arm.
Post Posted: Fri Oct 01, 2010 3:06 am
you need a jimny ps pitman arm. i fitted one to a cressida box and a couple of tamworthians are using them on vit boxes. they are a pinch shorter (7mm) i think , than the sierra arm and have similar drop and being suzuki the taper is right. genuine part number is 48671-81a20 and cost me $134.40. had to wait a couple of weeks from japan. made a clamp type steering dampener bracket to suit.
Post Posted: Fri Oct 01, 2010 4:29 am
im running twin uni joints joe, but will do so.
ill check my angles on the pitman arm to see if i can run a flat vit one...
Post Posted: Fri Oct 01, 2010 5:54 am
timmy has a PM :D
Post Posted: Fri Oct 08, 2010 11:13 am
no, 7 mm shorter than the sierra arm.... ish
Post Posted: Fri Oct 08, 2010 11:20 pm
the vit arm worked :D so now im off to find one end of the power steering lines for a cressida and the other jimny end.....
Users browsing this forum: No registered users and 161 guests
