It is currently Thu Jul 30, 2026 11:28 am
Post Posted: Wed Jul 28, 2010 9:53 am
I bought new a 2009 Jimny and it has a noise apparently in the transfer case when taking off in first gear under load, that is, taking off at set of lights from stop on a hill. The noise sounds similiar to a tyre rubbing on a mudguard. The problem is to be fixed under warranty but I have been told there is no guarantee that it can be fixed. I do not accept this as the noise devalues the vehicle. I believe some other Jimnys' have had same problem while under warranty. Does anyone have knowledge of this problem?
Post Posted: Wed Jul 28, 2010 11:24 am
It's not one I have heard of, but i mainly have Gv's & swift's as customer's.. what part of Brisbane you in??
Post Posted: Wed Jul 28, 2010 11:48 am
If its the case it can be fixed.
Put a new one in.
Don't let them rip you off!
I want my old sig back :(
Post Posted: Wed Jul 28, 2010 12:21 pm
Put a new one in.
May not need a new one..
May not even be the transfer..
Post Posted: Wed Jul 28, 2010 12:57 pm
I have had it since new.
Cant remember what it is, but it's not the TC.
As you can tell it's not a concern to me.
09 Jimny Sierra Limited Edition
Post Posted: Wed Jul 28, 2010 9:55 pm
Mine does that when i slip the clutch taking off up a hill. has done it since I got it 3 1/2 years ago. Recon it could be the thrust bearing?
Post Posted: Thu Jul 29, 2010 7:14 am
or the clutch slipping..
Post Posted: Fri Jul 30, 2010 9:59 am
Thanks for all the comments. It is not the clutch slipping as the noise can be heard constantly while driving up a steep incline such as a very steep concrete driveway.
The noise can also be reproduced driving on the flat at crawl speed in first gear and then stepping on the accelerator.
Guess I will let Suzuki do their stuff and see if it fixes the problem.
Thanks guys
Post Posted: Fri Jul 30, 2010 10:06 am
I would be very keen to hear the out come, so please keep us updated.. :P
Post Posted: Mon Aug 02, 2010 12:24 pm
Steknig, will do but will be a few weeks yet as waiting on parts from Japan.
Post Posted: Mon Aug 30, 2010 12:01 pm
New parts have been fitted to the transfer case to no avail. I am now waiting to see what Suzuki do next to fix this. I am rather annoyed as it took Suzuki about 10 weeks of indecision (they could not decide on replacing some parts or fitting new transfer case...they opted for the former) before fitting parts to transfer case.
Post Posted: Mon Aug 30, 2010 8:25 pm
Ive got a 4.0 v6 courier at work that does something similar its a gear meshing noise in this case . only under load after takeoff.
we fixed it with some moreys in the case and gearbox,but the box shifts slow when cold now.
ford told us it was not an issue and to live with it but these are notious for shitting gearboxes so we figured fuck it cant hurt I hope.
couriers also run ATF in the box and transfer so could be totally different thing for you
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Apr 24, 2015 5:31 pm
Silverwater, a few days ago I bought a second-hand Jimny (2010, 23000 km), which has exactly the same problem. Were you able to sort this out? I'd really appreciate it, if you could let me know what causes this noise.
Thank you!
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Apr 24, 2015 7:29 pm
I also have a 2009 model and from when I first got it (4,000 km) it had a transfer case noise a little like you describe. A year or so later I worked out that it was a stretched chain. It sort of makes a sound like a tyre rubbing on a guard when starting off in first. Eventually it stretched enough to slip on the gear teeth and then it was easily identified. The initial noise was the chain hitting the inside of the case. You might have this problem.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Apr 24, 2015 10:14 pm
Transfer chain. Its the known weak link expecially in autos
Post Posted: Mon Apr 27, 2015 11:54 am
Thanks for your replies, everyone!
Users browsing this forum: No registered users and 322 guests
