It is currently Fri Oct 30, 2026 9:25 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Fri Oct 26, 2007 11:53 pm
when i'm drivin around, my car spits and farts, especially when takin off, does the same on the highway, when it hit a hill just feels like it is miss firing!
i have checked all the leads and they are on!
its a 1.3l carb motor to!
n e ideas?
thanks
Vehicle: 75 Cruiser
Post Posted: Fri Oct 26, 2007 11:57 pm
i'm no tech guru, but anyway
have you tried removing each spark plug and seeing if they are all clogged up with black stuff? My number 4 gets clogged up and runs really rough after a while, depends on the angles you go on.
is your air filter clean? maybe there's dust build up that has gone in to the carby? you could try the old swap leads and backfire trick, or maybe spray carby cleaner everywhere, i love that stuff.
Post Posted: Sat Oct 27, 2007 12:01 am
yea i removed the spark plugs and cleaned them.
i havn't checked the air filter will do
thanks
Vehicle: 75 Cruiser
Post Posted: Sat Oct 27, 2007 12:05 am
did it happen suddenly one day, or gradually crept in? just thought, maybe you did something while working on the engine or somethin?
Post Posted: Sat Oct 27, 2007 12:15 am
accelorator pump in the carby or coil lead
is it worse when cold?
what colour are your plug leads? if not black have a real good look anywhere a lead goes within a inch or so of metal for little black arc marks
Post Posted: Sat Oct 27, 2007 12:17 am
yea a bit. but still bad when hot to.
they are red i think. ok i'll have a look!
thanks
Post Posted: Sat Oct 27, 2007 1:09 am
the lead is black!
and i can hear it click then it spits
Post Posted: Sat Oct 27, 2007 1:49 am
what clicks and what spits?
Post Posted: Sat Oct 27, 2007 2:02 am
i can hear it click when driving just before it miss fires!
Vehicle: 105 landcruiser
Post Posted: Sat Oct 27, 2007 2:32 am
or pop the hood when its dark...(with the car running):P
Post Posted: Sat Oct 27, 2007 12:39 pm
i started it up last night and i could see arc from the lead to those two nuts on the coil!
Post Posted: Sat Oct 27, 2007 11:13 pm
Sounds like the coil needs to be replaced.. Its insulation has been compromised. All it takes is a little crack.
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Sun Oct 28, 2007 1:50 am
yep replaced it today and is running good for now! thanks
Post Posted: Tue Nov 20, 2007 12:22 am
ok got this fixed,
well i started my car this morning, warmed it up them took off up the street and it died, there is no ignition lights, radio still works, it will turn over but won't start, and it keeps blowing a fuse everytime i put a new one in.
wat could it be?
thanks
Post Posted: Tue Nov 20, 2007 12:27 am
what fuse does it blow?
disconnect the negative wires off the coil and see where you get
Post Posted: Tue Nov 20, 2007 12:31 am
um the far left bottom one, ok will try thanks
Post Posted: Tue Nov 20, 2007 12:37 am
took them off, put fuse in and yea blown, still no dash lights
Post Posted: Tue Nov 20, 2007 12:42 am
now try the positive side
parkers and headlights working properly? or is high beam coming on when low beam should be?
Post Posted: Tue Nov 20, 2007 12:47 am
lights a fine, took positive off and dash lights come on but as soon as i went to start it, the fuse blew
Post Posted: Tue Nov 20, 2007 1:01 am
so with the positive wires off the coil it doesnt blow the fuse?
leave the wire going to the condensor (little round silver thing) off and try, otherwise could be a dead module
do you have 3 wires in total going to the coil positive?
Post Posted: Tue Nov 20, 2007 1:06 am
nah with the wires off, the dash light come on but when i kicked it over it blow,
there is only 2 wires to each pos and neg
Post Posted: Tue Nov 20, 2007 1:30 am
it blows when its cranking? what happens if you push start it?
Post Posted: Tue Nov 20, 2007 1:31 am
wats a module? and yea i can't get n e thing
Post Posted: Tue Nov 20, 2007 1:32 am
yea a soon as i hit the key to start it blows,
Post Posted: Tue Nov 20, 2007 1:34 am
then the dash lights go? interesting cause I dont think the start and ign circuits have anything to do with each other
got a wiring diagram?
Post Posted: Tue Nov 20, 2007 1:41 am
nah don't have a wiring diagram
Post Posted: Tue Nov 20, 2007 5:54 am
do you have an immobiliser installed. a bit of water got in mine, caused a short and blew the coil fuse every time i tried to start it. made some cool smoke and burning electrical smells too.
[img]http://www.auszookers.com/modules/coppermine/
Post Posted: Tue Nov 20, 2007 12:43 pm
nah don't have one of them, thanks n e way
Post Posted: Tue Nov 20, 2007 1:44 pm
mmm These days the immobilizer is installed inside the vehicle.. especially on 4x4's to avoid the whole water in the Immobilizer thing.
Unless you manage to flood the cabin?
Post Posted: Tue Nov 20, 2007 6:53 pm
its an all in one unit so the big siren had to be in the engine bay. and it wasnt actually 4x4ing that got it et, the guy at autoco gave my engine a complementary clean, and saw the thing was muddy so gave it a spray with the high pressure hose :? , needless to say they paid for the repairs :roll:
Users browsing this forum: Google [Bot] and 296 guests
