| Author |
Message |
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Fri Aug 06, 2010 12:40 am |
Morning all,
My rear brakes shoes are up for changing.
I've never changed the shoes before but have changed the pads on the front.
How do I go about changing them? I've taken a few pics but all of the springs etc are confusing me.
Is there anything in particular I should be aware of - handbrake etc?
Cheers,
Ben
_________________ 2002 SWB GV
Lifted and Locked
BlueSuzy
 Posted: Fri Aug 06, 2010 12:45 am |
What kind of Suzuki?
They are generally just a mess of springs and clips, do one side at a time to make sure you have the springs in the right way and position.
No not put your foot on the brake when changing them (like all brake changes)
Depending on what car is depending if you need to adjust them after they are done
The hardest bit is getting the springs back on. Have some good longnose pliers handy.
TheOtherLeft
 Posted: Fri Aug 06, 2010 1:20 am |
BlueSuzy wrote: What kind of Suzuki?
It's a 2002 J20A GV. What's annoying is I have a feeling the shoes may be from the older Vitara because the front pads are from the Vitara as well. I had a real headache trying to find the correct front pads as well.
Mess of springs and clips are bad...
Lifted and Locked
atari4x4
 Posted: Fri Aug 06, 2010 1:51 am |
They look very similar to the shoes in the back of my SV420 SWB which had different shoes to the SV620 LWB.
The Brake shop I use have a book of shoes with pictures of the the cutouts for the adjusters & springs, are you able to take as set in for comparison.
RHS front shoe
RHS back shoe
i was supplied with N1735 shoes which weren't quite right some of the holes didn't line up & the location of the adjuster wasn't right, took photo's of the original brake shoes & went back to Power Brakes & the right ones which are N1758
DSzuke
Joined: Mon Jun 22, 2009 11:30 pm Posts: 108 Location: Orange
 Posted: Fri Aug 06, 2010 3:48 am |
I ended up with the N1735 after much searching through the catologue
best to take them in for comparison (or a photo as suggested)
atari4x4
 Posted: Fri Aug 06, 2010 4:07 am |
DSzuke wrote: I ended up with the N1735 after much searching through the catologue best to take them in for comparison (or a photo as suggested)
The N1735 would be correct for the SV620 LWB Vitara.
VitaraJlx97
Vehicle: Suzuki Vitara Jlx 1997 2.0L
 Posted: Wed Apr 27, 2016 1:54 am |
Atari does the sv420 drum brakes have a auto adjuster i have a 97 model. And due to change mine.
tanshi
 Posted: Wed Apr 27, 2016 8:44 am |
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Wed Apr 27, 2016 9:12 am |
That's clearly the only solution to a six-year grave dig.
