It is currently Tue Oct 20, 2026 1:42 pm
Post Posted: Sun Aug 15, 2010 10:02 pm
I have just got myself a 90 model maruti, reading about it I can't really understand what it's got.
Can anyone tell me what's required to fit a 1.3 or better yet a 1.6 efi.
Post Posted: Sun Aug 15, 2010 10:11 pm
To fit a 1.3 you'll need to move the engine mounts or replace with 1.3 mounts.
To fit a 1.6 you can use an adapter kit that will bolt up to 1.3 mounts.
Gearbox tunnel will need enlarging a bit to fit 1.3 box.
Wiring, radiator mounts, airbox, exhaust is all different too but easily overcome.
Post Posted: Sun Aug 15, 2010 10:19 pm
Cheers for the reply if you have to enlarge the tunnel are you better to use a vitara 5 speed ?
My Maruti build, Click WWW
Post Posted: Sun Aug 15, 2010 10:35 pm
You'd have to enlarge it even more to fit a VIT 5 speed and then you'd have to use the VIT transfer or adapt the box to run a jackshaft to a Sierra transfer.. Lots more work.. Oh and gearbox mount would need work too.
Post Posted: Sun Aug 15, 2010 11:05 pm
So best way would be to take body off chasis to do it ?
Post Posted: Mon Aug 16, 2010 12:26 am
I reckon that would make the mods easier to undertake.
Post Posted: Mon Aug 16, 2010 1:33 am
Mate have a chat to Mr Rocky on here. He's got a 1.6L Baleno engine in his maruti and he did all the work himself.
Im guessing you have a 4spd box?
In which case the 5 spd guts from a 1.3L fit into the maruti 4 spd case. Not sure on how that would go matching up to a vit or baleno engine, but another option.
Post Posted: Mon Aug 16, 2010 1:35 am
Can anyone tell me where to find a wiring diagram for my maruti dash etc.
Post Posted: Mon Aug 16, 2010 2:23 am
not needed. the maruti has a 1.3 tunnel.
Post Posted: Mon Aug 16, 2010 2:40 am
Is this on the first maruti's ?
Is
Post Posted: Mon Aug 16, 2010 2:45 am
Anyone know what wiring diagram I need for the dash of my maruti
Post Posted: Mon Aug 16, 2010 3:50 am
Not real sure but I would say that 1.0 Sierra would be damn close.
Post Posted: Mon Aug 16, 2010 7:24 am
Anyone got one ?
Post Posted: Mon Aug 16, 2010 8:02 am
www.suzukiinfo.com
Post Posted: Tue Aug 17, 2010 4:56 am
* i used 2" body lift to clear bonnet (not sure if necessary)
* maruti g/box yoke fits the 5spd
* 5spd bolts to 4spd mounts
* j/shaft is the same
* radiator mounts are different and rad is smaller on maruti
* fire wall may need a bit of a bash with a hammer to clear motor
(for baleno)
* i used 1.6 fusebox and loom and powered and earthed wires from the ecu pinout diagrams (pj zook has these i think)
* sump and pick up may need to be swapped and modded (mine was already done)
* engine mounts are totally different for 1ltr ( i used 10mm plate bolted to standard mounts as per christovers mounts on outerlimits
* exhaust manifold is different
* I used a carby lift pump feeding an efi (maybe vl) pump where the fuel filter was near the tank on the chassie and relocated the filter to engine bay.
thats all i can recall of the top of my head
Users browsing this forum: No registered users and 355 guests
