It is currently Sat Oct 31, 2026 2:20 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Tue Nov 20, 2007 11:14 pm
well i had another go this arvo, put another fuse in and bam it ran, ran well got in to go for a drive, drove 10m and pop! the fuse went
Post Posted: Wed Nov 21, 2007 12:33 am
sounds like something is shorting out, start unplugging anything with a white/black wire
Post Posted: Sat Nov 24, 2007 12:58 am
ok i really need to fix this, i had a look around this arvo and can't find n e thing at all, can n e one think of n e thing it could be?
thanks
Post Posted: Sat Nov 24, 2007 7:09 pm
had a look around and found a wire in the loom that had rub in to the battery box, and was shorting out, i got a pease of wire and started the car, and put it on the wire then on the body, and it triped the fuse, so hopefully its solved
Post Posted: Sat Nov 24, 2007 11:39 pm
Yep, I'd say that would of been it mate. See told ya it was the same type of thing that Casper had a few months ago. Well done. :-)
Post Posted: Sun Jan 06, 2008 1:21 am
ok, need help again please!
i warmed the zook up today took off down the street and died,
i started it again and it started then died straight away, started again but had to keep reving it to keep it goin, its getting fuel threw the fuel line in to the carby and spark on all cylinders, n e ideas? thanks
Post Posted: Sun Jan 06, 2008 3:31 am
sounds like the idle jet in the carby is blocked....same thing happened to mine a bit........just swap plug leads 2 and 3 over....start the car and rev it a few times, letting it backfire out the carby......turn it off swap the leads back to normal and see how it goes after that
333...................im only half evil
Post Posted: Sun Jan 06, 2008 4:03 am
or knowing your wiring the plug could have fallen off
Post Posted: Mon Jan 07, 2008 10:15 pm
well it turned out to be a whole lot of water in the fuel tank. don't know how it got there, took the tank out, while parked on the side of the road drained it and pumped all the water out of the lines and filled it up again, after a few goes its goin
Post Posted: Wed Jan 16, 2008 12:32 am
does this work/is it safe?
mine wont idle now but runs fine(ish)
[img]http://www.auszookers.com/modules/coppermine/
Post Posted: Wed Jan 16, 2008 12:59 am
it worked for me.....or you could pull the carby apart and clean it all out, making sure you clean out the fuel bowl and idle jet, change fuel filters, possibly putting another fuel filter inline
i did the plug lead thing mostly as a temporary repair on the side of the road
Post Posted: Wed Jan 16, 2008 2:59 am
does the air filter thingy on the carby need to come off?
Post Posted: Wed Jan 16, 2008 12:09 pm
nah just pop the clips on the airfilter housing just incase
Users browsing this forum: No registered users and 612 guests
