| Author |
Message |
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Wed Aug 25, 2010 12:05 pm |
i know i should have searched first, but ive read most posts about flex over the last 6-12 months anyway... just went out for a quick trip with a mate, decided on a few shots. now, i knew i didnt have much flex, but i didnt know it was THIS bad...
now, my main question, is how much further would i expect it to drop if i remove the sway bar? im not keen on buying new springs/shocks...
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Aug 25, 2010 12:06 pm |
probably a fair bit. it won't suddenly flex its arse off but it will be a hell of a lot better than that AND it will be a lot smoother on the road.
also where is that? qmag area?
Fatzook
 Posted: Wed Aug 25, 2010 12:07 pm |
2-3" assuming your shocks are long enough
atari4x4
 Posted: Wed Aug 25, 2010 12:08 pm |
my vitara has more flex than that....
whincup
 Posted: Wed Aug 25, 2010 12:11 pm |
yes, but your vitara has a lot of work on it with quality brand springs and shocks. mine are cheap trak ryder springs from pedders up front, and OME springs in back, and OME shocks all round...
this is 2" spring lift, tyre size is 215/75R15...
appsie
 Posted: Wed Aug 25, 2010 12:12 pm |
looks like your climbing out of a hole a bit??in which case you cant really judge the flex.not in a sierra ive found anyway.
mine has ok flex lifted with the forklift and allowed to settle but hitting anything with momentum it sux the big one and is a issue id like to resolve.
Take off the sway bar and try man
Zook_Fan
take the sway bar out and maybe a leaf out of each pack.
whincup
 Posted: Wed Aug 25, 2010 12:13 pm |
Zook_Fan wrote: also where is that? qmag area?
this is back streets of gracemere, out behind the dump. pretty dry at this point so not anywhere near as much fun as it was 3 weeks ago...
whincup
 Posted: Wed Aug 25, 2010 12:14 pm |
appsie wrote: looks like your climbing out of a hole a bit??in which case you cant really judge the flex.not in a sierra ive found anyway. wish i could say that was the case, but i just crawled into it and stopped... not bogged, just because i was after photos... Zook_Fan wrote: take the sway bar out and maybe a leaf out of each pack.
yea i was thinking about taking the load leaf and maybe another out of the rear since i rarely, if ever, have anything in the back, then one out of the fronts as well... think im going to try one all round after tonight.
Zook_Fan
 Posted: Wed Aug 25, 2010 12:24 pm |
just remember if you do pull the leaf's out your car will drop slightly. i know you only have small tyres on there but it may be an issue.
suzukilwb
Joined: Sun Jul 19, 2009 11:30 pm Posts: 358 Location: milang
 Posted: Wed Aug 25, 2010 12:34 pm |
take the sway bar out i got heaps more flex out of my zook when i done it
neilss
Joined: Sun Sep 20, 2009 11:30 pm Posts: 72 Location: adel
 Posted: Wed Aug 25, 2010 12:36 pm |
this might sound dumb but whats the say bar, and if u can take it out whats its purpose
Zook_Fan
 Posted: Wed Aug 25, 2010 12:42 pm |
its purpose is to make the handeling of the vehicle better by making another link between the diff and the chassis it helps keep the inside wheel on the road in a hard turn, that sort of stuff. on the photo above you can see it (covered in mud) between the front end of the springs. by taking it off it lets the diff move more freely. it means that it does make the car handle slightly different on road, you may have to slow down on cornering marginally but they have little effect i have found
suzukilwb
 Posted: Wed Aug 25, 2010 12:44 pm |
neilss wrote: this might sound dumb but whats the say bar, and if u can take it out whats its purpose
pic to point it out
whincup
 Posted: Wed Aug 25, 2010 12:50 pm |
essentially it minimizes body roll, or swaying. it makes the car stiffer, and more responsive in cornering. from what i understand anyway...
might pull it out over the weekend
also love this pic because you can see my shiny new steering damper. only fitted this afternoon...
Fatzook
 Posted: Wed Aug 25, 2010 1:14 pm |
I think you should keep the swaybar, but give the rest to me
morpheus
Joined: Mon Oct 06, 2008 10:30 pm Posts: 689 Location: Adelaide
i had a sierra WT. and liked to throw it around the corners a bit... i removed the sway bar, and didn't notice any extra body roll at all in the corners..
so just remove it... but dont throw it away. cus i think its illegal to have removed it, and if you ever have to have an inspection done, you can put it back on for the day..
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Aug 25, 2010 1:44 pm |
almost all the sierras you buy in perth are missing their sway bar... its useless and crappy and should be recycled to make hyundais.
ditch the swaybar and see how you go ramping it up... measure EVERYTHING (droop and compression) - then unbolt the shocks all round, ramp it up and measure again - if the results vary your shocks are holding you back.
after that if you're still not happy, look into doing a RUF conversion.
Chopz
Joined: Thu Nov 12, 2009 10:30 pm Posts: 544 Location: Perth
 Posted: Wed Aug 25, 2010 2:56 pm |
1 swaybar=3 good paint stirrers
thats what i did with mine anyway
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Wed Aug 25, 2010 6:31 pm |
sway bar isn't going to do any thing for you. that looks like i still has the std shocks so that is the 1st point of call. unless you have really stiff springs the sway bar can stay on
royce
 Posted: Wed Aug 25, 2010 8:46 pm |
In that position a sierra will always do that, why do you think all the poser shots people put up are in that position
whincup
 Posted: Wed Aug 25, 2010 11:27 pm |
actually, on topic of RUF... is it possible to do one without welding/drilling the spring perches? every post ive read talks about doing either one of those...
tanshi
 Posted: Wed Aug 25, 2010 11:42 pm |
to do it well you should weld.
It can be done with out but is not ideal
BlueSuzy
 Posted: Wed Aug 25, 2010 11:48 pm |
if you want super stiff, i have 2 swaybars here for you. 3 swaybars up front should do it.
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Wed Aug 25, 2010 11:58 pm |
It never looks like as much flex when in that position. For comparison - two shots of my car, both with the same setup. RHS front was just off ground in the offroad photo.
Besides, flex is over-rated. Lockers are where it's at. Flex makes you look good, but lockers get you up and over.
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Thu Aug 26, 2010 12:52 am |
royce wrote: In that position a sierra will always do that, why do you think all the poser shots people put up are in that position
even coilys
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Aug 26, 2010 7:12 am |
jonno_racing wrote: even more so with coilys
Fixed for you
appsie
 Posted: Thu Aug 26, 2010 7:33 am |
which goes back to why i mentioned it in my post before.sierras love doing it  and x2 with royce
get over the flex and lock that shyt
pic 1 is driving toward pic 2,just infront of RH front wheel
driving out of the hole,that was july 09,its way worse now as i showed DEADZOOK and aerenandmel the other weekend....was fun
climbing a decent hill up through some washouts
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Thu Aug 26, 2010 7:51 am |
flex is over rated get lockers and go places.
appsie
 Posted: Thu Aug 26, 2010 8:02 am |
awesome
