It is currently Thu Oct 29, 2026 7:10 pm
Vehicle: 105 landcruiser
Post Posted: Mon Jan 21, 2008 8:45 pm
ok peeps shoot me down if you will
i have no idea
but do they replace the drive in all gears 4h 4l and 2h or just low grears
im not considering getting them just curious????
steve
Post Posted: Mon Jan 21, 2008 8:54 pm
they replace the transfer gears and depending on type they do different things
sierra ones dues to the design offer a lower ratio in both low and high range, sierras have a reduction in high range from factory as well, hence why they have 3.7-4.11 diff gears
vitara only lower the low range ratio as high range is direct drive through the transfer so there is no gears as such
Post Posted: Mon Jan 21, 2008 9:05 pm
thats what i thought....so if i were to put 38s on my vit (theroeticaly)
I would burn clutches in 2H
but I could do good in low range!
hmmm
so how do people run big tyres on vits ..or they dont on the road?
cheers royce i feel like a noob lol
Post Posted: Mon Jan 21, 2008 9:28 pm
more power of a vit means they dont seem to struggle too much, plus they have a pretty low 1st gear so that helps get em moving
Post Posted: Mon Jan 21, 2008 9:50 pm
a decent clutch wouldnt hurt i spose!
Post Posted: Tue Jan 22, 2008 2:32 am
Diff gears would be the only way IMO.
Post Posted: Tue Jan 22, 2008 3:23 am
ahhh what ratios are available ? has any one changed them on here ?
i know different years and gearboxes have different diffs but are there aftermarket options?
Post Posted: Tue Jan 22, 2008 5:43 pm
The other way is to run dual transfers like Ant does. Basicly you bolt a Sierra transfer to the rear output on the Vit transfer and get custom drive shafts made up. I think this would only be possible on the LWB Vits as the SWB wouldn't have enough room.
Here is the Calmini Vitara gearset I recently installed into my Vit.. Its Very SLOW hehehe.. :wink:
Thanks,
Chris
http://www.nbs4x4club.com
Users browsing this forum: Google [Bot] and 118 guests
