It is currently Mon Oct 26, 2026 7:38 pm
Vehicle: Zookless
Post Posted: Fri Jan 25, 2008 11:27 pm
Both of my rear drums have started to weep brake fluid. :cry:
Both are very slow, as in, no noticable drop in the brake fluid reservoir, so hopefully I have a little time to fix the problem.
Unfortunately I do not have much experience with brakes at all. From the pics, can you guys tell what the problem could be, and if so what replacement parts it would require?
Post Posted: Sat Jan 26, 2008 1:14 am
diff oil is my guess. looks like you might need some new seals.
[IMG]http://img.photobucket.com/albums/v711/richmo
Post Posted: Mon Jan 28, 2008 10:56 pm
No I would pull the wheels and drums off and look at the wheel cylinders. They are about $40 each from repco. But check that the brake shoes are ok or just replace them at the same time, for a 1984 model they are around $35 for a rear set.
Cheers,
Peter
Vehicle: 75 Cruiser
Post Posted: Mon Jan 28, 2008 11:44 pm
yeah give that a go first.
1. leave the wheel on
2. undo the 4 hub nuts
3. take the handbrake off
4. kick the tyre , left side, then right side til the wheel moves loose on the hub nuts and then remove the wheel with the hub attached.
see if the fluid is coming out the ends of the brake cylinder
Post Posted: Tue Jan 29, 2008 1:02 am
if you can see fluid on the backing plate its all stuffed inside anyways from contamination I'm afraid
youll need some brake shoes, I would replace the cylinders leaking or not (I would say thats what it leaking anyway) and give it all a good clean
they arent hard if you do one side at a time so you can use the other side as a reference but if you arent sure dont risk it and take it to a mechanic
Post Posted: Fri Feb 01, 2008 7:58 pm
What happened with this one?
My guess was diff oil too, I haven't come across brake fluid leaking on the back of the backing plate unless the brake pipe has come loose, been left loose or fractured. Wheel cylinders normally just make a mess inside the drum and leak out the bottom eventually.
Vehicle: Zookless
Post Posted: Sat Feb 02, 2008 10:22 pm
Here's the result.
Brake fluid AND diff oil. 8O
Looks like I'm up for a slightly bigger job than expected.
Post Posted: Sun Feb 03, 2008 1:59 am
No biggie, just check your wheel bearings while you're at it,sometimes flogged out wheel bearings can cause the seal to leak, that's a bigtime leak! But hey parts are cheap.
Users browsing this forum: Google [Bot] and 349 guests
