It is currently Sun Jul 26, 2026 6:51 am
Post Posted: Sat Sep 11, 2010 3:12 pm
G'day
there was a few posts about shrockwork sliders (link below).
http://www.shrockworks.com/Suzuki-Samur ... 16143.html
here is what i did with few small differences. what most people and me included don't like about the design is that sliders bolt to the body and chassis. I mounted them only to the body. using 4 bolts through the floor and 6 (4 would be prabably enough :) ). I removed stock plastic seals, removed metal rusted brackets cleaned everything with flap disc resulting with only 1 small 5mm hole in one rust infected spot, painted etc. I cut off most of that hot pressed (welded??) ends of sills leaving and enlarging drain holes. water drains now on and outside of angle shaped rock-sliders. I used RSH instead of pipe for side step, because it was easier to cover them with checker plate. it's not slippery, protects a bit from mud and match few other checker plate bits on my zook. all feels very solid and strong, I did not use high lift jack, because I don't have one, but I wouldn't hesitate to. I leaned car onto the sliders on some deep ruts and banks with no problem.
finished sliders, checker plate not on yet
mounting through the floor and sills
finish result
Post Posted: Sat Sep 11, 2010 8:17 pm
Nice work, but I don't see any scratch's on em yet!! :P
Do you have crush tube's going through the sill's??
Post Posted: Sun Sep 12, 2010 12:53 am
pictures were taken after mounting slider to the car
yeah
Post Posted: Tue Sep 14, 2010 7:33 am
nice i have been looking at building some identail 2 but with tube not rhs :) i like this
Post Posted: Wed Sep 15, 2010 7:20 am
I like, well done
