It is currently Fri Nov 13, 2026 1:24 pm
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
Vehicle: Zookless
Post Posted: Fri Sep 10, 2010 12:34 pm
OK, tanks is in, HP lines all round. Thanks Blu.
How much pressure is the system anyway? Seems strange that they require high pressure lines, but use those crappy "spring type" hose clamps.
Sumps have been cut. I'll take it to a welder on Monday to get TIG'd.
Post Posted: Fri Sep 10, 2010 2:17 pm
Spring type! Piss them shit things off!! Just use some descent stainless hose clamps on it.
Dan
Lil Foot!
Online
Post Posted: Fri Sep 10, 2010 3:07 pm
never use those shit clamps.. they are shit.
Post Posted: Fri Sep 10, 2010 8:00 pm
Dan
:? Um..... That what Suzuki use on the Gv's, shift's, Sx4's, Jimny's, Apv's, you get the idea.
Thay work fine as long as the clamp & hose is suited for the application..
Online
Post Posted: Fri Sep 10, 2010 10:55 pm
Yeah cheap suits the application.
Post Posted: Fri Sep 10, 2010 11:03 pm
CairnsZook wrote:
The coily tank is going in today.
Do I need to run high pressure lines for supply and return? Or can I run normal lines for return?
It would be fine to use the factory low pressure supply line (the metal one on chassis) as a return as the return is not under pressure.
Online
Post Posted: Fri Sep 10, 2010 11:12 pm
alot of people run the factory steel lines, for both supply and return.
I have run this for more than 3 years.
Vehicle: Zookless
Post Posted: Sat Sep 11, 2010 8:10 am
Yes, I'm using the existing steel lines. Just new HP lines at both ends.
At $30 per meter, I wouldn't want to have to do the whole lot 8O
Post Posted: Sat Sep 11, 2010 8:26 am
I swap the charcoal canister line with the return line of the tank, give's you a bigger return line..
Post Posted: Sat Sep 11, 2010 8:28 am
Just wondering can you weld the sump with an oxy or should you get it tig'd ?
My Maruti build, Click WWW
Post Posted: Sat Sep 11, 2010 8:30 am
Either or..
I've welder em with oxy, welded fuel tank's with oxy to..
Post Posted: Sat Sep 11, 2010 9:00 am
Just because i have an oxy but not a tig :) Will an oxy be too hot ? and distort it ?
Just wondering what you cut the sump parts with ?
cheers.
Post Posted: Sat Sep 11, 2010 9:02 am
The one's I welded were cut with rock.. :lol: :lol: :lol:
Vehicle: Zookless
Post Posted: Sat Sep 11, 2010 9:04 am
I cut them with a jigsaw, then spent ages with a hand file to get it fitting nicely.
Post Posted: Sun Sep 12, 2010 12:07 am
any furthure progress ??? :D
Vehicle: Zookless
Post Posted: Mon Sep 13, 2010 10:38 pm
Anyone got the part number for the rear gearbox seal?
Ripco ordered in the wrong one for me...
And which VL Dunnydoor engine mounts have people used?
Left, right, rear, 6 cyl, 8cyl? They didn't have any there for me to look at.
Post Posted: Tue Sep 14, 2010 8:03 am
Same same left to right, eng mount's, not gear box mount.. :P
Gear box out put seal..
http://www.suzistore.com.au/shopexd.asp?id=598
Post Posted: Tue Sep 14, 2010 8:28 am
http://cgi.ebay.com.au/Holden-VL-6cyl-e ... 3f031c8b97
they are what i am useing.. no breakage yet and i try my hardest :)
Post Posted: Tue Sep 14, 2010 8:40 am
jonno_racing wrote:
http://cgi.ebay.com.au/Holden-VL-6cyl-engine-mount-NEW-PAIR-/270635142039?pt=AU_Car_Parts_Accessories&hash=item3f031c8b97
That's them!!!!!!!
Vehicle: Zookless
Post Posted: Tue Sep 14, 2010 11:55 am
Thanks Steaks, I ordered one from there this arvo.
Also got new clutch cable, gearbox bushes, and gearbox plugs (cos I had to chisel one out :roll: )
Those mounts look good Phil, I'll get some of them too :)
Here's my very flash machined flywheel:
And my pink HD clutch:
All bolted together :D
Post Posted: Tue Sep 14, 2010 12:03 pm
Good luck with the pink HD clutch. I am taking mine out cos I keep breaking clutch cables. :x
Going with standard Exedy :oops:
Post Posted: Tue Sep 14, 2010 11:39 pm
Haven't had an issue at all with mine, feels nice and light on the pedal too :D
Lil Foot!
Vehicle: 4wd
Post Posted: Tue Sep 14, 2010 11:44 pm
Looks like the spiggot bearing is sitting too high?
Watch out or you'll get sued.
Vehicle: Zookless
Post Posted: Tue Sep 14, 2010 11:46 pm
It's in flush with the flywheel. Might just look like that because it's new and shiny :)
Online
Post Posted: Tue Sep 14, 2010 11:51 pm
I run a single row, double width in mine as the spigot shaft is slightly worn, like most sierra's. But to get the flywheel bolts undone, you cant just hammer it in to get them undone as a socket wont get full contact, i have a dynabolt welded to rod as a slide hammer/bearing puller. Works a treat. :lol:
Vehicle: Zookless
Post Posted: Thu Sep 16, 2010 9:06 am
Here's the welded sump, with a fresh coat of paint:
And the oil pick-up.
I cut the top off both pick-ups and fitted the Baleno top into the Sierra tube.
The support tab was also cut off the Baleno and welded onto the Sierra tube.
Vehicle: Zookless
Post Posted: Thu Sep 16, 2010 9:11 am
The Baleno dip-stick looks like it's about the right length.
What do you blokes reckon?
Post Posted: Thu Sep 16, 2010 9:54 am
+2
EDIT: All the stories about broken clutch cables. I bought a spare clutch cable just incase it broke. 30,000km later, still no issues, spare clutch cable is still stored in my car.
Post Posted: Thu Sep 16, 2010 10:41 am
+2
x3 my clutch is softer than the factory one..
fatzook your doin it wrong.
Post Posted: Thu Sep 16, 2010 11:03 am
ive had a exedy sports tuff , and now i have a custom npc racing clutch and both are light although clamp pressures vary dramatically , if you have a heavy clutch pedal you are doing it wrong (or they are)
Users browsing this forum: No registered users and 51 guests
