It is currently Fri Nov 13, 2026 10:16 am
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Post Posted: Tue Sep 28, 2010 11:58 pm
The connectors are pretty good and cant go on backwards.
Have you touched the timing at all?
No teeth chipped on the bottom pulley for the sensor?
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 12:39 am
Haven't touched the timing.
I'll go and double check the plug to the CAS.
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 2:42 am
WIN!!!
She started!!!!! yess!!
JrZook wrote:
The crank angle sensor is a critical part of the timing
I remembered that when the sump was welded, the flange around the crank angle sensor was not quite straight. Well, it was out far enough that the magnet was not picking up the teeth as they went past.
The sensor was angled towards the rear of the engine too much. So I carefully shaved off part of the rear section (a little bit at a time) until it was straight.
Post Posted: Wed Sep 29, 2010 2:49 am
HOORAH!!
Post Posted: Wed Sep 29, 2010 2:57 am
Does it go fast !
Good work mate !
My Maruti build, Click WWW
Post Posted: Wed Sep 29, 2010 3:47 am
HOORAH!!
:P :P 8)
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 8:09 am
xedent wrote:
Does it go fast?
Yep :P and loud with no exhaust :twisted:
I just did the traditional "Auszookers run with no exhaust after an engine swap" 8)
I'm nearly out of beer and the bottle-o is just down the hill anyway...
Post Posted: Wed Sep 29, 2010 10:23 pm
CairnsZook wrote:
xedent wrote:
Does it go fast?
Mine was with straight extractors :lol:
Awesome sound. Pop crackle burble. It gave me shivers and i was shaking for 20mins after the 1st flat stick run ripping up 3rds down my street. :lol:
Vehicle: Zookless
Post Posted: Wed Sep 29, 2010 10:50 pm
She's booked in to get a new exhaust tomorrow.
Lukey extractors and a 2" sports system :D
Post Posted: Thu Sep 30, 2010 1:40 am
Lets hope the extractors fit..
If i go g16b again, i will be buying g13bb jimny ones
Vehicle: Zookless
Post Posted: Thu Sep 30, 2010 2:18 am
So you're saying that Jimny extractors will definitely clear the engine mount?
There seems to be a lot of confusion as to which Vit extractors will fit...
Post Posted: Thu Sep 30, 2010 2:22 am
Jimnys have a very similar chassis spacing to sierra's. Its not the engine mount that is the problem, its how they run next to the chassis.
Vits have a bigger chassis, so some make extractors with more room to play.
I bought vit ones, then had to modify them to suit. Waste of $300, and special order so couldnt return them, and too far away from where i bought them also! (wildcat114 meant to be 2 types, same number)
Post Posted: Thu Sep 30, 2010 2:30 am
also depends what jimny ones you get, as the ones highway star has also fowl on the chassis and engine mount.
Vehicle: Zookless
Post Posted: Thu Sep 30, 2010 2:31 am
OK good stuff - Jimny extractors it is then.
How did yours line up with your existing exhaust?
Post Posted: Thu Sep 30, 2010 2:36 am
Mine was all new 2"
So i guess its a Lucky dip with the jimnys also. :?
Vehicle: Zookless
Post Posted: Thu Sep 30, 2010 3:03 am
The bloke at Carline really want's to go with Vit extractors.
I said Jimny, he reckons they have different heads. Then I told him the Baleno and Jimny have the same manifold gasket he finally started to believe me...
Maybe I'll just try these http://www.bestmufflers.com/bshop/produ ... 8dd8d6fd94
Post Posted: Thu Sep 30, 2010 3:06 am
make sure your talking about g13bb jimny, the m13 will probably be different??
Post Posted: Thu Sep 30, 2010 3:32 am
yes the m13 jimny will definatly be different.
Post Posted: Thu Sep 30, 2010 3:34 am
Thats the place i got my extractors from. Wildcats, not many place sell them. Made in....africa..
Post Posted: Thu Sep 30, 2010 7:25 am
The quality in this tech build looks unreal 8)
Vehicle: Zookless
Post Posted: Thu Sep 30, 2010 8:01 am
Thanks mate :P
I would have never even attempted it without Auszookers. I've been researching this literally for years now, and have kept a close eye on other threads.
Zookernator
Bluesuzy (thread on "the site we don't mention around here") :lol:
Zachius
Damo (Where is Damo these days anyway?)
PJ.zook's wiring diagram.
And JrZook for his online interstate trouble shooting Armsup
Vehicle: Zookless
Post Posted: Sat Oct 02, 2010 8:12 am
I picked up a new Sierra temperature sender today.
The Baleno sender is bigger, with a different thread too. Luckily I found an adapter lying around that fits perfectly!
The Baleno plug has three wires going to: ECU, Baleno temp gauge, and Sensor ground. The Sierra sender has one.
The engine will not run if the Baleno plug is not connected. I assume this is because of a missing ground???
Post Posted: Sat Oct 02, 2010 8:29 am
The ecu need's that one, that's the CTS ( coolant temp sen) should still run tho. :?
Post Posted: Sat Oct 02, 2010 9:21 am
i would just get an aftermarket temp or try and graft the baleno one from the tacko into yours ?
Post Posted: Sat Oct 02, 2010 9:35 am
hey mate, looks sweet!!!!!!! how long before she is set to hit the tracks? i am trying to organise a all zook run next weekend?
Vehicle: Zookless
Post Posted: Sun Oct 03, 2010 12:49 am
Just waiting for extractors to arrive, and need to sort out air-intake piping. Do you know a good place to get flexible rubber piping in Hobart?
I'll be up for a test run - somewhere fairly close to home though, just in case...
Post Posted: Sun Oct 03, 2010 9:07 am
what do u need pipeing for mate? purple pig?
we are going to start up at jeffreys if your keen. trying to get as many zooks as possible!
Vehicle: Zookless
Post Posted: Mon Oct 04, 2010 5:03 am
Air intake is complete :D
I just need to tidy up a bit of the old wiring, and the engine bay is done.
I've grafted the Baleno temp gauge into the Sierra instrument cluster.
It's wired basically the same as the Tacho. 3 wires, signal, ignition and earth - easy enough I thought...
But when I start the car, the needle goes all the way to the top. I must have accidentally swapped a couple of wires :?
Vehicle: 85 Suzuki Sierra
Post Posted: Mon Oct 04, 2010 5:08 am
That looks like the bottom of the gauge to me. ~_~
Your engine bay is also unusually clean :). Very nice.
Orange LWB Sierra
Vehicle: Zookless
Post Posted: Mon Oct 04, 2010 5:12 am
Yeah that's a pic showing the gauge. The needle actually goes straight to the top as soon as the ignition is on.
Users browsing this forum: No registered users and 62 guests
