It is currently Thu Oct 08, 2026 12:52 am
Post Posted: Thu Oct 07, 2010 9:02 am
My Jimny is coming up for a service soon and I have been having the oil changed around every 6000ks. Apart from the 1st time which I used Valvoling 10-40w semi-synthetic I have been using Nulon 5-30w full synthetic which I really like and it has not used a drop but as I get the car serviced at a mechanics so the warranty is not affected I was thinking of going to the 7500km service schedule to save some money as the Nulon is expensive and is suppose to be long life. How often do you guys change your oil.
Paul
Post Posted: Thu Oct 07, 2010 9:05 am
10,000 for me.
Post Posted: Thu Oct 07, 2010 9:29 am
i do mine every 5,000 or a bit over. i use hpr 10 which is a semi synthetic. cost me $45 for a botle of oil and filter when supershit has there 20% off sales. to regards to your question, i reckon doing your service every 7,500 will be fine.
Post Posted: Thu Oct 07, 2010 12:44 pm
do mine every 5000
use that valvoline magnatec stuff, think its 10w-40
Post Posted: Thu Oct 07, 2010 1:10 pm
I used to change my 300ZX every 3000kms. That was expensive :cry:
The ute gets done every 10,000 now, and the vit will be every 7500 I reckon.
Post Posted: Thu Oct 07, 2010 1:13 pm
do mine every 5 - 6000. also do the filter every time. i probably dont have to do the filter that often, but meh. i go to the beach almost every weekend and the little car gets worked pretty hard. the oil is pretty black at each change.
Vehicle: Jeep
Post Posted: Thu Oct 07, 2010 2:04 pm
I have always done mine every 5000kms, and i always use an oil flush, but, if the engine has been worked hard quite a few times, i change it more often, i keep an eye on the colour of the oil, and how it smells as well, to give me a good indication of how the oil is doing... i used to use Valvoline 15W40 Semi Synth, but now i have the GV, i will be using a better quality oil, maybe Nulon or Penrite Semi Synth, in a 10W40 :wink:
Post Posted: Thu Oct 07, 2010 6:33 pm
Penrite semi-synth (HPR10 in winter HPR15 in summer) done every 5000, transfer, diffs and gearbox done every 10000 also Penrite.
Post Posted: Fri Oct 08, 2010 5:54 am
Thanks for the responses.
Paul
Post Posted: Fri Oct 08, 2010 9:53 am
really?
Post Posted: Fri Oct 08, 2010 11:38 am
really?
x2
i do mine every, oh i dono, 30 000
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Oct 08, 2010 2:14 pm
Royce clued me up here - black oil ain't bad, that's how I used to gauge if it needed a change myself. I've since read a quite few online articles and stumbled onto similar magazine snippets on the matter and it seems oil is good long after it turns black. It's only shot when it starts to thicken... hard to tell off the dipstick tho.
Stick to the service manual and it's recommendations - Suzuki knows best.
Post Posted: Fri Oct 08, 2010 7:54 pm
your not going to hurt anything execpt possibly your sump plug thread buy doing exessive oil changes :wink:
but your wasting your money doing them any earlier than 7500km - 10000 on a petrol daily driver
yes change it sooner on your bush hack , it might be the thing that saves your motor( I do mime every 5-10 drives with a 15 40 diesel oil if its getting a hard time)
diesel oil change intervals are different as they need the oil changed at set intervals to get the soot out of the block before it blocks up things and wears bearings etc
Post Posted: Fri Oct 08, 2010 8:15 pm
you have to factor time as well, the additives in oil break down from the first time the oil is used and usually needs to be chucked in 3-6 months depending on the oil quality
which sucks for cars driven every 6 months :(
Post Posted: Fri Oct 08, 2010 8:22 pm
really?
Absolute overkill? Yeah but I guess its as much about the therapy of playing with the car as it is about maintaining it in general.
Total cost to do all 4 is about $40-50 in oil and an hour and a half or so of time, cheap really in the whole scope of things.
Post Posted: Fri Oct 08, 2010 8:28 pm
the book would list it as 40000km I reckon, you would get better long term results putting $200 oil in every 40000 that cheap stuff every 10
A question for all the I drop my oil more than I change my daks people, how often do you change your coolant and brake fluid and other filters and what do you use? these are all heaps important and often overlooked
Post Posted: Fri Oct 08, 2010 11:14 pm
Well said.
2002 SWB GV
Lifted and Locked
Post Posted: Sat Oct 09, 2010 6:34 am
on my personal cars I do coolant and all oils every 40,000
all fully syn stuff, oil filter every change and air and fuel every 20,000
on the work stuff
all oils evey 40km coolant when the system is open for some reason
air and fuel every 20km (these cars may do up to 60,000a yr)
brake fuid never :wink: Im trying to get rid of a few workers
my on site cherry pickers every 100 yrs in summer and 160 hrs in winter oil and oil and air filters
hyd oil every 1000 hrs
Post Posted: Sun Oct 10, 2010 2:44 am
on the work stuff
8O 8O 8O 8O
Post Posted: Wed Jul 06, 2011 2:27 am
Just a quick query for you penrite boys (such as myself)
I Use transaxel 75 for the transfer case and gearbox (as per penrites site reccomendations) and Hypoid 80w/90 for the Diffs, I notice that the api rating for the hypoid is api GL-5. but the manual calls for gl-4.
Got on the phone to penrite, they just say they stand by their reccommendations and its better than gl-4. But i heard different on other forums saying it will stuff up your diffs.
What do you guys use/reckon?
PS I use everyday full synth 10/40 for the engine if anyone was curious. and i do every 5000k
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Jul 06, 2011 7:50 am
A transaxle is a front wheel drive gearbox, which also incorporates a diff. The oil is designed to work with the diff (hense the GL5 rating) but also works fine with the syncros.
Post Posted: Wed Jul 06, 2011 8:23 am
thanks scrawn, im not having an issue with the gearbox oil specs. its the diff oil im enquiring about. sorry for confusion
Post Posted: Wed Jul 06, 2011 9:49 am
on the work stuff
brake fuid never :wink: Im trying to get rid of a few workers :lol:
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Wed Jul 06, 2011 10:02 am
I WILL start doing mine very 10,000km's!
Post Posted: Thu Jul 07, 2011 7:22 am
My bad, I was skim reading as usual while the kids were crawling over me.
You really want a GL5 rated oil in the diff. GL4 just won't give the right lubrication and protection for the ring and pinion gears
Post Posted: Thu Jul 07, 2011 8:02 am
I use Mobil 1 5-50 fully synthetic. I mainly use that because i give it a hard time around the rev limiter. Change oil & oil filter every 7000 or so.
Post Posted: Thu Jul 07, 2011 9:59 am
i change mine engine oil/filter every 5000km which is about every 6-8 weeks,
AJSR- why do you say this? ("your wasting your money doing them any earlier than 7500km - 10000 on a petrol daily driver")
Post Posted: Thu Jul 07, 2011 11:59 am
I did mine the other day after 12k. sing Shell something 10-40 or somewhere abouts.
Since i have had a real wierd buzzing sound coming from the engine (like a remote control sound). Any idea?
Mitch.
Users browsing this forum: No registered users and 310 guests
