It is currently Mon Oct 19, 2026 10:18 am
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3  Next
Post Posted: Mon Oct 11, 2010 6:27 am
Can it be done? Or will I set fire to my vitara? :roll:
I know that I SHOULD run them through a relay, but in a pinch, can I run them off the standard headlight wiring??
Post Posted: Mon Oct 11, 2010 6:40 am
dunno you try and if your car doesnt burn down ill try it just make your bar and mount some hid's and leds to it
Post Posted: Mon Oct 11, 2010 6:41 am
should work for a night or two before it burns out the switch... or finds the highest resistance joint to melt.. :D
Have seen it done, but due to the wiring lengths you end up with about 2-4 volts drop so the bulbs have such low voltage you get no material gain in light output.
better & cheaper to put some H4 plus 30 (or plus 50) 55/60w bulbs in, as the vits have the plastic rear light housings and these housings will melt if you put high wattage (read as high heat) bulbs in.... found that out a while ago....
Post Posted: Mon Oct 11, 2010 6:42 am
P=IV
I=7.7amps
so 21 guage or 0.73mm^2 wiring...NFI what standard is
Think before you post to make AZ a better place :)
Post Posted: Mon Oct 11, 2010 7:01 am
Ok, well in light of the above comments, does anyone have a wiring digram for running the headlights through a relay?
Post Posted: Mon Oct 11, 2010 7:03 am
No, but its dead simple...
Put 12V on one end of the relay coil, and the original headlight wire to the other.
The on the other side of the relay, put the headlight circuit. Make sure you run a decent sized earth as well as 12v cable to the headlight!
I want my old sig back :(
Post Posted: Mon Oct 11, 2010 7:06 am
Any chance of a No0bCaD drawing?? :lol:
:P It will melt Mr fat..
Post Posted: Mon Oct 11, 2010 7:09 am
I already have the 90/110's tho :cry:
Post Posted: Mon Oct 11, 2010 7:12 am
:P Give em to Rusho & watch his coily burn.. :P
Post Posted: Mon Oct 11, 2010 7:14 am
pete wouldnt you just wire them like spotties
and stekky its a coily and nothing fits them so the bulbs props wouldnt
but a few litres of petrol and a match would
Post Posted: Mon Oct 11, 2010 7:20 am
They have metal housings :lol:
Vehicle: SJ80
Post Posted: Mon Oct 11, 2010 7:24 am
Rusho's safe... fire wouldn't even be compatible with a coily, unless you could get some customised to suit :lol:
Vehicle: Suzuki
Post Posted: Mon Oct 11, 2010 7:28 am
This is pretty much how my headlights and spots are wired, I didn't make the diagram, I found it on here when i first came along.
Post Posted: Mon Oct 11, 2010 7:52 am
seen it on a vitara pete, wasnt pretty
Post Posted: Mon Oct 11, 2010 7:53 am
Haha..
I'll see what I can do when I get home...
Vehicle: 93 Sierra
Post Posted: Mon Oct 11, 2010 7:58 am
Noobcad it is! Scanned this when I wired mine up so I could trace it back more easily if anything ever went wrong....
Relay for high beam, relay for low beam and relay for each pair of spots.
Post Posted: Mon Oct 11, 2010 8:22 am
Get stuffed you pair of pricks :cry: My head lights are crap...they are sealed so i don't need bulbs :roll: :roll:
Post Posted: Mon Oct 11, 2010 8:23 am
mate i can join you with the crap lights i figure some hid's or led's will fix this that or a hid head light kit
Vehicle: '94 suzuki maruti
Post Posted: Mon Oct 11, 2010 8:27 am
agree and disagree with this. yes it does work, i use those bulbs in mine... but yes, its not much brighter than whatever the stock bulbs are. ive been meaning to do the relay upgrade for a while, just been too slack... il learn my lesson when i have to replace a chunk of wire though ;-)
Post Posted: Mon Oct 11, 2010 8:50 am
Are you talking about a Vitara or sierra?
My main concern now is that the plastic housing may melt. :?
Post Posted: Mon Oct 11, 2010 8:54 am
When I put relay's and good globes in the Sierra it made a massive difference to the amount of light they were putting out.
yeah id be worried of that but hey just get some bits laser cut to remove the plastic haha
Post Posted: Mon Oct 11, 2010 8:56 am
Yeah maybe.
Or I'll just buy some new ones :roll:
I've gone off the HID kits. They are too unreliable, the cops are starting to defect them, as they are illegal, and too many oncoming cars with abusive drivers.
Post Posted: Mon Oct 11, 2010 8:58 am
& you think 90w low beam's won't piss people off?? 8O :?
Post Posted: Mon Oct 11, 2010 8:59 am
haha he will be right he is a big boy me on the other hand i may need to start carrying a bigger mag light to smack people and run
Post Posted: Mon Oct 11, 2010 9:06 am
throw them in the bin and smack yourself about the head for even thinking of it, wattage doesnt equal light output
go get some philips plus 50 or 80 or whatever they are up to now, then relay them suckers too
Vehicle: 93 Sierra
Post Posted: Mon Oct 11, 2010 9:43 am
Surprisingly not, no. I have 100/130W H4's in mine and due to the ride height can angle them right down but still get a good spread. Oncoming traffic doesn't get any glare unless its a bumpy section of road where any headlights will 'flash' as the nose of the car rises.
It does mean my high beams now have a shorter throw, but that makes them great mid-fill. I have HID driving lights for distance.
Royce - it might not be directly proportionate (haven't got a clue what the relationship is) but they are way better than the Narva 55/60W +80%'s I had in there previously. I can drive quite happily on a twisty country road using my headlights only (no driving lights) - couldn't do that with the +80%'s. Not to mention that BOTH of those same expensive new Narva globes blew low beam less than 4 hours into a trip across the Nullabor. I had two 100/130W spotlight globes in the back so dropped them in to finish the trip, and they were so good that they've stayed there ever since...
Definitely agree you wouldn't want 90/110 or 100/130 with a 'normal' beam pattern though. You have to be prepared to dip them right down and use driving lights for distance.
BTW this is the difference you can expect between running stock wiring loom (12.5v at light) versus relay (14v) with H4's. And this is the difference between stock D1's and Narva +80% H4's.
Post Posted: Mon Oct 11, 2010 10:24 am
I use the phillips H4 100/90W ($13 pair) in my sierra in IPF housings ($60 each from ARB) and they are fantastic.
Did a loom upgrade while I was at it.
The high beam will pick up eyes at about 1km.
The only issue I have is the relfective road signs strain the eyes if i go past with high beams on.
Low beam is fine if aimed correctly.
Post Posted: Wed Oct 13, 2010 8:15 am
u want to get some of these http://www.powerbulbs.com/product_detail.asp?prod=111
they are better then 100w globes and dont melt any thing
heaps of guys are running them in the club
Users browsing this forum: DamoRed83 and 265 guests
