It is currently Sat Sep 26, 2026 11:35 pm
Post Posted: Thu Oct 14, 2010 3:01 am
Anyone used them or know who sells reversed wrapped leaf springs (eye wrapped under the main) in Briz? Seems to be a spring option im looking for. Long main leaf without excessive overall lift+minimal spring inversion under full compression compared to std wrap springs.
Dan
Lil Foot!
Post Posted: Thu Oct 14, 2010 3:23 am
funny i spoke to someone today that said their front springs were reverse wrapped
I think the brand was Lovells the place i was speaking to was wa suspensions
cheers
lost in suzuki space
yes.. i've used them on my first zook. They are made by lovells. They flex awesome
Post Posted: Thu Oct 14, 2010 4:00 am
Cheers!! Got anymore pics rpmwrx?
Lil Foot!
Post Posted: Thu Oct 14, 2010 4:06 am
You can see my lovells fairly well here:
I want my old sig back :(
Post Posted: Thu Oct 14, 2010 4:45 am
this is all i've got of it flexed up :)
Post Posted: Thu Oct 14, 2010 4:46 am
Cheers Ben! So im assuming both front and rears are both reversed wrapped. How many leaf in each pack? Did you have to take any out?
If possible could I get a few measurements off you such as bumpstop clearance(since u run ext shackles could i also have your shackle eye-eye length). A side on pic would be great just to show off the shackle angles on flat ground.
Now to try and track down a brisbane distributor :?
Cheers Dan!
Lil Foot!
Post Posted: Thu Oct 14, 2010 4:49 am
Thanks RPM! Mmmmmm your rears don't seem to be reversed wrapped tho? They also lovells?
Lil Foot!
Post Posted: Thu Oct 14, 2010 4:50 am
I can get some measurements and things but probably not til tomorrow... I'll count the leaves tonight though. Didn't remove any leaves.
Bear in mind I have stupidly long dodgy homemade shackles put on by a previous owner...
Post Posted: Thu Oct 14, 2010 5:01 am
probably revearsed wrap, but who cares, as long as they flex back into the normal position then there's no problem... This is why i run OME leaves on my current zook as the springs have excellent memory. Extended bump stops help as well...
Yes the rears were lovells as well, teamed up with Koni shocks... are you going to run RUF?
Post Posted: Thu Oct 14, 2010 8:07 am
I care :P
I also now have koni shocks, but im looking specifically for reversed wrapped springs front and rear. I do not run bumpstop spacers because I have a virtual lift and the tyres clear. The reverse wraps deffinatly look alot happier under compression than the std wrap springs. Yea im also considering going RUF
Lil Foot!
Post Posted: Thu Oct 14, 2010 8:26 am
You need a Uhf before you need new spring's.. 8O
Vehicle: Zookless
Post Posted: Thu Oct 14, 2010 8:50 am
If you talk while you're wheeling like you post here, than I'd turn my UHF off too :roll: :? :lol:
Post Posted: Thu Oct 14, 2010 8:57 am
Max-trac springs are reverse wraped as well :wink:
:lol: Then I'd pretend I din't hear you ask for a tow.. :P :lol:
Prick.. :lol:
Vehicle: Zookless
Post Posted: Thu Oct 14, 2010 8:58 am
:cry:
:P
Post Posted: Thu Oct 14, 2010 9:15 am
i had lovells in mine pre-SPOA.. they were brilliant! very flexy and held their height - and they didnt develop the suzuki lean.
Vehicle: Zookless
Post Posted: Thu Oct 14, 2010 9:20 am
Were yours lifted Alien? Or standard height?
I'm liking the sound of these too!
Post Posted: Thu Oct 14, 2010 9:33 am
mine were 2" lifted - im not sure they were reverse wrapped though. Lovells are one of the few that make the leaves longer with the lift too.
Post Posted: Thu Oct 14, 2010 6:16 pm
i due to a lift on my sierra soon what are pricing on lovell compared to ome springs
Post Posted: Thu Oct 14, 2010 8:18 pm
how long are the lovells compared to ome? anyone
Post Posted: Thu Oct 14, 2010 9:09 pm
i dont know why but 950mm e-e comes to mind - cant remember if thats front or rear - and it would be with the weight of the zuk on it.
Post Posted: Thu Oct 14, 2010 10:38 pm
Yes another good question as I currently have OME in mine and I still think they have made their mains too short!
Lil Foot!
Post Posted: Fri Oct 15, 2010 5:03 am
i found out the other day that OME (or was it EFS?) have different rears for LWB and SWB.... SWB are 60mm longer than stock and LWB are only 10mm longer as theyre prone to inverting the shackle on the LWB.
Vehicle: Zookless
Post Posted: Tue Oct 19, 2010 12:58 am
I wonder howthesewould go? Obviously they are designed for SPOA, but I don't see why you couldn't run them SPUA.
Although, they way they overlap may make removing leaves a bit limited.
I might have to start lurking on some Yank forums to get some info...
Post Posted: Tue Oct 19, 2010 1:07 am
Shouldn't be an issue removing leaves. Their pretty much like a normal spring pack bar the extra half leaf up the top used to try and keep axle tramp under control
Lil Foot!
Vehicle: Zookless
Post Posted: Tue Oct 19, 2010 1:16 am
Yank reports aren't looking great so far...
http://www.pirate4x4.com/forum/showthread.php?t=893360
http://bbs.zuwharrie.com/content/topic,71857.0.html
Although, none of them have mentioned removing leaves yet.
Vehicle: Zookless
Post Posted: Fri Oct 22, 2010 1:18 am
I sent an email to Sean at Lowrange:
Hi Sean,
I'm interested in the Bonz Eye 2in lifted leaf springs.
I will be running them in a spring-under configuration and will most likely remove a leaf to gain some extra flex.
Have you heard of anyone over your way running them like this?
Would you have time to take some measurements of the springs?
Eye to eye along the top of the main spring.
And also the spring arch height, from the eye to eye centre-line down to the top of the main leaf.
Front and rear please.
His reply:
We would not suggest taking out a leaf at all.
All I have in stock at the moment is the front springs so email linda at TT for the info on the springs.
My email to TT:
Hi Linda,
I'm interested in the Bonz Eye 2in lifted leaf springs for a Suzuki Samurai.
Linda's reply:
Front - 35 3/4" eye to eye in a straight line.
37 1/2" along the main leaf eye to eye.
4 7/16" arch height center line to top of main leaf
Rear - 39" eye to eye in straight line
40 1/4" along main leaf eye to eye
4 1/4" arch height center line to top of main leaf.
Thanks,
Linda
Trail Tough Products
1-877-789-8547
www.trailtough.com
In Aussie talk:
Front:
908mm - eye to eye in a straight line.
952mm - along the main leaf eye to eye.
112mm - arch height center line to top of main leaf
Rear:
990mm - eye to eye in a straight line.
1022mm - along the main leaf eye to eye.
108mm - arch height center line to top of main leaf
Post Posted: Fri Oct 22, 2010 1:49 am
Sweet finally some descent tech!!! Can anyone add the dimensions of their leaf packs to this? EFS etc?
Lil Foot!
Vehicle: Zookless
Post Posted: Tue Dec 07, 2010 5:24 am
Finally got around to measuring mine...
Old sagged Dobinsons, measured eye to eye, along the main spring.
Front - 940mm
Rear - 1100mm
Users browsing this forum: Google [Bot] and 103 guests
