It is currently Thu Oct 08, 2026 12:14 pm
Post Posted: Tue Oct 19, 2010 11:58 pm
Hey everyone, I couldnt find anything on this, but when welding stuff to the diff housing eg, perches, brcing it and diff armour, do you need to take the axles out and the diff oils etc?
Cheers.
Post Posted: Wed Oct 20, 2010 12:08 am
Cheers.
No you don't
But be very careful when you're welding, make sure you don't overheat and warp the axle housing
With perches, weld the outside edge of the left perch on.. Then the outside of the right, then inside left inside right, etc etc.. Make sure it has ample time to cool.
Post Posted: Wed Oct 20, 2010 12:24 am
I would be striping it to a bare housing if you are laminating, bracing and doing diff armour, you can get away without stripping it if you are only doing perches.
Post Posted: Wed Oct 20, 2010 12:43 am
x2
And if you can get the housing professionally degreased in a parts washer ( big hot water washing machine basically) then your welds will have a better chance of be contaminant free.
Users browsing this forum: No registered users and 80 guests
