It is currently Mon Oct 26, 2026 10:50 pm
Post new topic Reply to topic  [ 415 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 14  Next
Post Posted: Thu Oct 21, 2010 7:21 am
steak_knife wrote:
tombutt wrote:
whats the drivers side head light like mines cable tied in as all the bolts snapped
:? different to my knowledge..
I have heard the same :?
i can confirm that rumour....
Post Posted: Thu Oct 21, 2010 7:33 am
efi fuel tank?
Post Posted: Thu Oct 21, 2010 7:36 am
Ridge wrote:
efi fuel tank?
Nah, was a G16A.
Post Posted: Thu Oct 21, 2010 7:40 am
want33s wrote:
Ridge wrote:
efi fuel tank?
Nah, was a G16A.
Um will it still have a 5.12 diff then :?
Post Posted: Thu Oct 21, 2010 7:45 am
Joe wrote:
want33s wrote:
Ridge wrote:
efi fuel tank?
Nah, was a G16A.
Almost 100% sure but will confirm in the morning when I remove the front.
Post Posted: Thu Oct 21, 2010 7:47 am
want33s wrote:
Joe wrote:
want33s wrote:
Ridge wrote:
efi fuel tank?
Nah, was a G16A.
Ok cool 8)
Post Posted: Thu Oct 21, 2010 7:50 am
how big are the spring spacers? 15mm and 30mm?
Post Posted: Thu Oct 21, 2010 8:19 am
Will measure them in the morning but yeah they looked about 20mm.
Post Posted: Thu Oct 21, 2010 9:41 pm
It has 30mm in the front and none in the rear but the rear sits really high so they must be GV springs or something else.
$30 if you want them.
Post Posted: Thu Oct 21, 2010 10:01 pm
Price and measurement from hub center to wheelarch lip on the rear springs?
Post Posted: Thu Oct 21, 2010 11:12 pm
550mm $30 the pair
Post Posted: Thu Oct 21, 2010 11:25 pm
550mm $30 the pair
If that includes 50mm for the bodylift and no spacers ill grab em, ill sort out a time on the weekend later on
Post Posted: Thu Oct 21, 2010 11:27 pm
550mm $30 the pair
There are no spacers in the rear and 550mm is without the bodylift in. Would be 600mm WITH bodylift.
Post Posted: Thu Oct 21, 2010 11:29 pm
want33s wrote:
550mm $30 the pair
holy shit thats some tall springs!!!
Post Posted: Thu Oct 21, 2010 11:44 pm
You can always cut a coil or two off...
Want to take this thing to the tip ASAP peoples...
Have got:
* the nose cone bit above lights. $10
* Pair of headlights & taillights. $10 each
* Pair of locking hubs, also suit GV upgrade. $100
* front and rear tailshafts. $20 each
* G16A starter motor. $50
* 30mm front spring spacers. $25
* 50mm bodylift. $40
* Complete soft top with all fittings. $50
* Transfer case. $50
PM or ask here if theres other bits you want.
Post Posted: Fri Oct 22, 2010 12:01 am
ill take the coils, whats the condition of the top and more importantly the rear window like?
Post Posted: Fri Oct 22, 2010 12:08 am
The top is actually pretty good under all the dirt. The windows are still clear and no rips anywhere that I can see.
The zipper on the rear window doesn't zip cause the teeth aren't interlocking. Not sure if you could fix it with patience or a new zip be needed.. All the teeth appear to still be there.
Post Posted: Fri Oct 22, 2010 12:42 am
ill ask on the top (not for me)
ill take the washer jets and the little metal mounting tabs if they are still there, the door switches if they arent busted
Is it a JC bodylift? does $40 include removal :)
Post Posted: Fri Oct 22, 2010 2:23 am
OK
OK, yep
OK
Not a JC hence the price drop from $100 to $40. Already out of car.
Post Posted: Fri Oct 22, 2010 6:54 am
nah, dont worry about. thanks tho
Post Posted: Sat Oct 23, 2010 8:13 pm
The front centre is here too.. It is a 5.12:1... Complete (alloy) centre $100
Post Posted: Sun Oct 24, 2010 8:44 am
ill grab the body lift off you :) what nic is it in?
Your off ya tree
Post Posted: Sun Oct 24, 2010 8:46 am
Yeah OK... Includes most of the body rubbers too.
Post Posted: Sun Oct 24, 2010 9:09 am
do you still have the rear springs if so how much including post to 4108?
what is the spring rate like?
Post Posted: Sun Oct 24, 2010 9:35 am
I'm after a drivers side headlight if you are willing to separate them.
It will need to be posted to 2800.
Post Posted: Sun Oct 24, 2010 7:51 pm
Royce got the rear springs and both the headlights....
Post Posted: Tue Oct 26, 2010 5:14 am
no worries... ta :)
Post Posted: Tue Oct 26, 2010 5:24 am
have you got an auto set up?
Post Posted: Tue Oct 26, 2010 7:35 am
I'm guessing you mean an auto transmission......
No it was a 5 speed manual.
Post Posted: Sat Nov 20, 2010 9:33 pm
Still got a few bits laying around....
Nose piece above lights.
Pair of taillights.
Pair of driveshafts.
Soft top with ALL clips,catches, screws etc.
G16B Vit cam and angle drive dissy with new cap.
G16B bottom end.
Crossmember for gearbox.
Users browsing this forum: No registered users and 84 guests
