It is currently Thu Oct 22, 2026 5:32 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Wed Oct 20, 2010 9:31 am
I don't know how much work this would involve, but would it be worth trying to use lada niva brakes + master cyl on the sierra?
Preferably calipers + discs, whole hub if necessary.
Been thinking about it for a while, thought it'd be pretty handy on steeper decents?
Post Posted: Wed Oct 20, 2010 9:32 am
where is the advantage over vit wagon brakes?
Post Posted: Wed Oct 20, 2010 9:35 am
Post Posted: Wed Oct 20, 2010 9:40 am
dont they run a weird 3 piston progressive calliper?
Post Posted: Wed Oct 20, 2010 10:44 am
Yes, a two stage brake master cylinder and 3 piston calipers.
light depression of the brake operates only the first state which operates only the centre piston on the caliper.
Their hubs are also the same stud pattern if I remember correctly?
Post Posted: Wed Oct 20, 2010 11:12 am
Might go down to U-pull it next week and get some calipers + master cylinder.
See if it'll work.
Post Posted: Wed Oct 20, 2010 11:45 am
8O LADA
Post Posted: Wed Oct 20, 2010 11:46 am
8O LADA
Whhhattttt?
The brake design is good except some what flawed.
I imagine it'll feel like a permanently spongy pedal lol.
Post Posted: Wed Oct 20, 2010 11:53 am
save yourself the hassles & get some LWB vitara front calipers & disks.
Post Posted: Wed Oct 20, 2010 12:00 pm
I'm assuming that's a simply bolt on job?
Post Posted: Wed Oct 20, 2010 6:33 pm
yep, just have to cut around the caliper because the vit caliper is bigger, and you will need to bleed it off the disk as the nipple is in the wrong position...
Post Posted: Wed Oct 20, 2010 7:26 pm
Have you driven a Lada?? 8O
Go drive one, then come back & tell us the brake's are good..
Cause you won't. :lol:
Post Posted: Thu Oct 21, 2010 6:21 am
Can't be much worse lol.
It's the two stage thing I was considering really.
Post Posted: Thu Oct 21, 2010 6:27 am
2 stage, do you mean stand on the brake's & stop when you hit something?
:lol:
Vit is bolt on & frigging awesome in the peddle feel & stopping power, get even better if you do a rear disc to.. :P
.... you will need to bleed it off the disk as the nipple is in the wrong position...
I've never cut a caliper apart, and I definately can't even pretend I can understand the engineering that goes on with them, but is it at all possible to redrill and tap a new bleed point in onto the caliper?
Or is the position of the bleed point set in the fact that it's at the furtherest point of the system?
Post Posted: Thu Oct 21, 2010 6:29 am
i don't know about the new point but the original bleed points are set in the highest point of the caliper so the air gets pushed up and out
You could strip the caliper's down, re drill then re kit them, or just flip em up..
How often do you bleed your brake's??
Post Posted: Thu Oct 21, 2010 6:38 am
Glavas wrote:
8O LADA
Whhhattttt?
its good, but bad at the same time???
Post Posted: Thu Oct 21, 2010 9:42 am
by the way when the lada front pads wear down they fall out of the caliper completely - WHEN DRIVING 8O 8O 8O
Post Posted: Thu Oct 21, 2010 9:47 am
:P Oh 2 stage!!! :roll:
Now I get it, once the pad's run out you use the piston's!! :lol:
Post Posted: Thu Oct 21, 2010 9:52 am
bakerboy wrote:
Glavas wrote:
8O LADA
Whhhattttt?
Good in the sense that you can gradually brake. Useful for steep decent.
Flawed, in the sense that on road you would get what is effectively a spongy brake pedal feel all of the time.
Vehicle: 1987 sierra tray back buggy
Post Posted: Thu Oct 21, 2010 10:00 am
Glavas wrote:
bakerboy wrote:
Glavas wrote:
8O LADA
Whhhattttt?
cant ya brake gradually in any vehicle? or am i imagining that
Post Posted: Thu Oct 21, 2010 10:24 am
matty87 wrote:
Glavas wrote:
bakerboy wrote:
Glavas wrote:
8O LADA
Whhhattttt?
Not in the same way. From my ( alas, limited) 4x4 experience, down steep decent it's hard to do "gradual braking."
Every time I try it I seeimgly lock up and start sliding (clay/mud) or come to a sudden stop (sand)
Post Posted: Thu Oct 21, 2010 10:31 am
1+6.5+4.1 in that order=FTW ?
if you can decipher that.
Post Posted: Thu Oct 21, 2010 10:34 am
Don't know what the 1 is for? :S
6.5 t case gears? 4.1 diff ratios?
I just wanted something cheap and quick I can whip up. When my Gbox gives way, i'll get the rear locker and 6.5's.
Post Posted: Thu Oct 21, 2010 10:39 am
1 stands for first gear :)
yeah man im just messing, i do however tink that kiss is prolly a good plan of attack with brakes as is tnt (tried n tested) especially on a road car.
Post Posted: Sat Oct 23, 2010 12:01 am
Yeah I'm leaning towards that.
I'll suss getting Vit calipers...might even do a disc rear.
My car is a daily, but I can easily go without for as long as I need to :)
Post Posted: Sat Oct 23, 2010 12:22 am
I did the LWB Vit calipers n rotor on my maruti, no trimming required, and bled the system with the calipers in position.
It is a very very simple job, bleeding takes longer than the RnR
Post Posted: Sun Oct 24, 2010 3:50 am
You still running the factory drums on the back?
How do the brakes perform?
Post Posted: Sun Oct 24, 2010 3:57 am
Paulv has done an excellent and easy to follow write-up HERE.
Users browsing this forum: Boggomobile and 178 guests
