It is currently Fri Oct 16, 2026 9:48 pm
Post Posted: Sun Oct 24, 2010 9:37 am
hey all, checked my motor the other day at work and didnt like wat i found, i have a very very minor leaking head gasket and the compersion is down on the two middle pistons. 180psi on tha two end ones and 125psi on the two middle ones . is that bad ???? is it cheaper and easyer to just get another motor out of a zook or swift barina ect. or rebuild mine?
2''lift 31's twin locked & 6.5s
Post Posted: Sun Oct 24, 2010 9:46 am
it would be cheaper to change head gasket than to change the motor. a lot less stuffin around! and cheaper of cource.
If you don't get stuck you aint tryin' hard enough
Post Posted: Sun Oct 24, 2010 9:49 am
ok but wat about tha compresion could that be part of tha head gasket or somwthing else?
Post Posted: Sun Oct 24, 2010 10:00 am
More than likely the gasket, get the head serviced while it's off or get a good 2nd hand one..
Post Posted: Sun Oct 24, 2010 10:08 am
o ok ill keep that in mind any thing else that i should do when its apart ?
Post Posted: Sun Oct 24, 2010 7:40 pm
Cam belt, front crank seal, thermostat, rad flush..
I could keep going.. :roll:
Users browsing this forum: No registered users and 236 guests
