It is currently Thu Oct 22, 2026 10:54 am
Post Posted: Mon Oct 25, 2010 4:28 am
Ok, so i had a guy call me today, a mate of a mate of a mate or something thinking i would know how to flat tow a jimny with no true neutral behind his motorhome :roll:
Now never ever even been in a jimny let alone familiar with their transfer set up i said i would aske the oracle. He wants to know if there anyway he can select a true neutral in the transfer case?
i hope that makes sence
cheers weaves
Post Posted: Mon Oct 25, 2010 4:55 am
Take out the rear driveshaft...
I want my old sig back :(
Post Posted: Mon Oct 25, 2010 5:05 am
Put it on a trailer, saves adding zillions of Ks to the clock that were not driven.
Vehicle: '96 LWB trayback
Post Posted: Mon Oct 25, 2010 5:36 am
I work with a bloke who does a lot of "grey nomad" touring. Towing first a sierra, then a jimny behind his motorhome.
Said he has had troubles with both lunching either gearbox or transfer (Can't recall which) due to oil starvation.
He had identical troubles with both and the join that repaired them said it was common with towed zooks. A common complaint of grey nomads.
His solution was to fit a rear disconnect. Quick and painless when it was time to set up camp and go driving.
Post Posted: Mon Oct 25, 2010 5:39 am
If the ing not on thay don't count it..
Post Posted: Mon Oct 25, 2010 5:41 am
There's a company that convert em to a braked trailer, I think that use rear disconect & a servo on the brake peddle, not cheep tho..
Vehicle: Jeep
Post Posted: Mon Oct 25, 2010 5:46 am
I actually saw a new model SWB GV being towed behind an enormous Camper/home on wheels, with all 4 wheels on the road, they had a A frame setup onto the camper tow hitch... i was amazed to see that, didnt get any pics as i was driving at the time... but yeah, it would just add wear to it without even being driven :roll: on a trailer would be the way to go...
Post Posted: Mon Oct 25, 2010 6:46 am
yeah that would by my company mate.. hitch and go , we are the brisbane suppliers and fitters.
Post Posted: Mon Oct 25, 2010 6:52 am
:P
Post Posted: Mon Oct 25, 2010 7:12 am
i seen this in NZ aswell.
ill steer him towards a rear disconnect.
losfer, if you want to pm me or post some contact details, i can swing the details his way, but im also unsure of his budget
weaves
Post Posted: Mon Oct 25, 2010 7:15 am
http://www.hitchngo.com.au/
:P
Vehicle: 1987 sierra tray back buggy
we towed a gq patrol behind a 40' bus around oz a framed with 4 wheels on the ground. Had to leave the keys in the ignition to keep the steering lock off and put the transfer in neutral from memory never had a problem.
going down long hills dad would get me to sit in the car with it ideling and use the brakes when he did as the bus brakes would overheat after a while. we took the car off a few times going down hills at first then tried it with the car on it was acctually better with the car on to use the car brakes to help the bus fanc that.
as for doing it again the old man recond he would get a smaller car and put it on a trailer.
Post Posted: Mon Oct 25, 2010 7:27 am
http://www.hitchngo.com.au/suzuki.html
no Jim's.. :?
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Mon Oct 25, 2010 7:29 am
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Mon Oct 25, 2010 7:33 am
So I could tow a swb with Sully.. :lol: :lol:
Post Posted: Mon Oct 25, 2010 7:55 am
I'd need to tow a workshop behind me, for any of the cars i've owned :)
Dreaming of a warrior conqeror with my Vit on the back http://www.allterrainwarriors.com.au/in ... 3&Itemid=8
Post Posted: Mon Oct 25, 2010 9:17 am
Post Posted: Mon Oct 25, 2010 9:35 am
The current GV's have a true neutral in the T/Case that the owner's manual says is specifically for flat towing.
Post Posted: Mon Oct 25, 2010 8:39 pm
Wouldn't happen to be Bob Carlisle would it? He asked me how the Jimny went when i went to see him about my wedding rehearsal at his chapel.
I have seen jimnys put on a tommy lift sort of fork thing. Drive side on to the rear of the camper and it hoists the car. Shitload of weight on the arse end...but i HAVE seen it, so it can be done.
Mitch.
Post Posted: Mon Oct 25, 2010 9:51 pm
This guys name is John. And i'm unsure of any of his setup or his budget.
Does anyone know of a rear disconnect for the jimny?
Post Posted: Mon Oct 25, 2010 9:57 pm
sierra rear disconnect should work shouldnt it?
Post Posted: Wed Oct 27, 2010 12:01 am
Will a Sierra transfer fit into a jimny?
Post Posted: Wed Oct 27, 2010 12:07 am
i believe it can be done
Users browsing this forum: Google Adsense [Bot] and 240 guests
