It is currently Thu Oct 22, 2026 3:47 pm
Post Posted: Tue Oct 26, 2010 9:08 pm
Looking at some gearing ideas for the vit
I have 4.2:1 in the vit case but it doesn't do high range
Wat do u recon of running a stock Sierra case behind the vit on with 4.6 diffs and 31 maybe 33
Do u recon it would load up the Sierra input to much when the vit is in low and sierra is in high
Wouldnot use 8:1 very much but 2:1 in the Sierra case would be nice on the beach and on dirt roads where 4:1 is to low
Would the tale shaft angle be to bad wIth the offset out put the vit is a lwb so the shaft is pretty long
Post Posted: Tue Oct 26, 2010 9:12 pm
Also would it be better mated or devorced
Post Posted: Tue Oct 26, 2010 10:26 pm
you would have to run it devorced. a better solution would be to get a pair of 5.12 diffs which would help lower high and low range.
Post Posted: Tue Oct 26, 2010 10:41 pm
or even better some after market diff gears.
duals is alot of work and not going to be great in a vit
Post Posted: Tue Oct 26, 2010 11:42 pm
I have 5:12 and 5:83 are to prone to damage
Post Posted: Tue Oct 26, 2010 11:43 pm
If I were to do duals in my vit I'd use a second vit case. IMO it would be stronger than the Sierra case
Tanshi:
Why would duals in a vit not be great? IMO gearing is good and once it's setup another stock transfer can be had pretty easy if it everlet go. if it's a 1.6 vit it will already have 5.12s and I'm pretty sure there arent many if any aftermarket diff options
Jmo though
Inbits
Post Posted: Tue Oct 26, 2010 11:53 pm
my big issue with it would be that, unless you put reduction gears in one of the cases as well its not a great deal of gearig for the work involved,
also the offset of the rear diff will give you drive line issues, just not really worth it.
Post Posted: Wed Oct 27, 2010 12:21 am
Using A Sierra transfer you would get the driveshaft issue but using a second vit one I think would be worth it IMO. joeblow runs vit twins in his Sierra and as far as I know he doesn't run reduction gears in either of them. I could be wrong though :lol:
Post Posted: Wed Oct 27, 2010 12:23 am
again......best option.
http://www.lowrangeoffroad.com/suzuki/s ... drive.html
Post Posted: Wed Oct 27, 2010 12:25 am
granted!
Post Posted: Wed Oct 27, 2010 12:41 am
I looked at that but ur stuck with a 6:1 low then and 4:1 is to low for some things as it is but not low enough for other stuff that's y I thought that the Sierra case would be good as it gives the option of a 2:1 low 4:1and 8:1
Post Posted: Wed Oct 27, 2010 12:43 am
you know when you are in low you can jsut change up a gear if its too low
Best thing would be if Joe made 1.4:1 portals for vits
Post Posted: Wed Oct 27, 2010 12:45 am
with a standard sierra case how do you get 8:1.
vitara low range is 1.8
1.3 sierra case is 2.2
that give a low low range of 4:1
Post Posted: Wed Oct 27, 2010 12:46 am
I have 4.2:1 vit gears
Users browsing this forum: No registered users and 131 guests
