It is currently Wed Oct 14, 2026 12:46 am
Post Posted: Thu Oct 28, 2010 8:37 am
hey guys,
Been creeping this site for a while now and have decided to do a g16b conversion on my sierra.
The baleno motor is what i have decided to go with but there's a couple of things i haven't been able to find.
First is the mounts. Will a benT adapter kit mount the engine into the sierra bay or will i need custom or another type of engine mount?
Also what exactly needs to be done to the sump?
cheers.
heres a piccy of my sierra.
Post Posted: Thu Oct 28, 2010 8:55 am
You should find all the answers you need here mate: http://auszookers.com/index.php?name=Fo ... pic&t=6423
I want my old sig back :(
Post Posted: Thu Oct 28, 2010 9:07 am
in that he mentions that he bought the benT kit but also was looking at VL engine mounts or something?
is the benT kit still needed for the conversion or do i just need the holden VL engine mounts?
Post Posted: Thu Oct 28, 2010 9:08 am
Im pretty sure you need both. :)
95 Sierra, SPOA, 33 JT2s, 5.12s.
Post Posted: Thu Oct 28, 2010 9:11 am
I'm pretty sure BenT would have designed the mount spacer to use the standard Sierra mount....
the VL mounts are an upgrade to the standard mounts.
Post Posted: Thu Oct 28, 2010 9:25 am
http://www.auszookers.com/index.php?nam ... conversion
Post Posted: Thu Oct 28, 2010 10:01 am
ben T kit is to mount ur gearbox to the engine and use some vl engine mounts
Post Posted: Thu Oct 28, 2010 10:24 am
The BenT kit has an adaptor to use the Sierra mounts...
Post Posted: Thu Oct 28, 2010 10:43 am
oh my bad ive only seen the adapter plate for the gearbox
Post Posted: Thu Oct 28, 2010 7:37 pm
It does, but with slight mod (grind locater off) to the Vl mount thay fit, giving you stronger than piss weak 1.3 mount's..
As for the mounts that bolt to the block, just use you 1.3 one's.. :P
Users browsing this forum: No registered users and 229 guests
