It is currently Fri Oct 02, 2026 1:07 am
Post Posted: Thu Oct 28, 2010 8:56 am
Ok I just connected up my spotties and took the car for a test drive..
When I am just cruising along the road they run fine.
But when I am on a track at low revs and then I feed it to the engine. The fan belt starts to slip.. I don't understand why?
It is a bit loose and I am going to tighten it. But it only seems to slip when I turn the engine on cold (Fine after about 10 seconds and only slips when revving) But now it slips whenever I have the spoties on? :)
My build: Click WWW
Post Posted: Thu Oct 28, 2010 9:01 am
extra load placed on the alternator is causing the belt to slip when the spotties are on
Post Posted: Thu Oct 28, 2010 9:03 am
So... Can that be fixed? Or just tighten the belt?
My build: Click WWW
Post Posted: Thu Oct 28, 2010 9:05 am
yes.... by tightening the belt :wink:
Post Posted: Thu Oct 28, 2010 9:26 am
you can also buy a product called Belt Grip. We sell stuff at work by crc, alot of people use it so it can't be too bad
Post Posted: Fri Oct 29, 2010 1:10 am
Replace it and tighten properly
Post Posted: Fri Oct 29, 2010 5:56 pm
Belt Grip x 2. I am running a Falcon 110 amp alternator in a 92 vit. During heavy winching I get belt squeal. The CRC belt grip certainly helps but you have to keep applying it from time to time.
Users browsing this forum: Google [Bot] and 190 guests
