It is currently Fri Nov 13, 2026 5:09 pm
Post Posted: Sat Oct 30, 2010 3:31 am
I tightened my fan belt the other night... And now.. For some stupid reason I am leaking coolant from somewhere behind there... :?
This is the best photo I can get of it.. And I am asking on here as I cannot get any closer to it than that..
The leak is quite extreme with it dripping out of there at about 2 or 3 drops per second...
I have a feeling that I may have bumped something when I was tightening the belt.. Any ideas of what it could be??
EDIT: I am asking this because I have never pulled apart this section and I don't know what is under there that could possibly be leaking.
My build: Click WWW
Post Posted: Sat Oct 30, 2010 3:37 am
water pump has had it, probably why the belt as loose
look up from underneath you will see the vent hole its coming from
Post Posted: Sat Oct 30, 2010 4:07 am
This the hole?
My build: Click WWW
Post Posted: Sat Oct 30, 2010 4:13 am
Yep, it's stuffed and needs replacing.
thats him
Post Posted: Sat Oct 30, 2010 4:14 am
Ok.. Will that be difficult to replace?
How would I best go about it?
My build: Click WWW
Post Posted: Sat Oct 30, 2010 4:33 am
Pretty simple to do if you are fairly mechanically minded. You will need to pull the timing belt off first to get the pump off.
Post Posted: Sat Oct 30, 2010 4:52 am
Get a new one of them to..
Post Posted: Sat Oct 30, 2010 4:55 am
Why is that?
I think I will just buy a new water pump than get the Mechanic to swap them over.. I don't really want to play around with the timing belt.
My build: Click WWW
Post Posted: Sat Oct 30, 2010 5:06 am
sickzuk1 wrote:
steak_knife wrote:
Why is that?
because you have to take it off, so you may as well fit a new one, then you know when it waas fitted & don't have to wory about it for another 100k.
Post Posted: Sat Oct 30, 2010 5:15 am
Ok. How hard is it to put the timing belt back on?
I have never pulled one of these off or anything but how difficult is it? Will it just be better to buy the parts then get a mechanic to fit them?
My build: Click WWW
Post Posted: Sat Oct 30, 2010 5:29 am
Some one, can't remember who did a good write up on how to replace em, pic's & all, it in the rig section, somewhere..
did a search & couldn't find it..
Post Posted: Sat Oct 30, 2010 6:00 am
http://cgi.ebay.com.au/Suzuki-Swift-Sie ... 1494wt_972 ?
My build: Click WWW
Post Posted: Sat Oct 30, 2010 6:05 am
that will do, however I am not aware of any swift using a sierra pump, the bolt pattern for the pulley is different
Post Posted: Sat Oct 30, 2010 6:12 am
So it may not fit?
My build: Click WWW
Vehicle: Clown Car..
Post Posted: Sat Oct 30, 2010 6:48 am
sickzuk1 wrote:
So it may not fit?
the pump itself will fit, its the pully on the shaft that you may have issues with.. but if your upgrading the alternator to a 110amp and changing pullys then this is not of any concern as you can use the swift pully.. but you will need to change the crank pully, at the same time..
Post Posted: Sat Oct 30, 2010 12:40 pm
Turn the engine to line up the timing marks BEFORE removing the timing belt - it'll make replacing it so much easier.
Post Posted: Sat Oct 30, 2010 9:52 pm
you can leave it on and still remove the water pump if you are careful not to slip it off, but it pays to mark it with some whiteout on the cam pulley and the crank just incase, allow a couple of hours at least if you havent done it before.
Post Posted: Sun Oct 31, 2010 1:52 am
It's a pretty straight forward job on most zooks.
Got a workshop manual? It explains the exact procedure in there!
Post Posted: Sun Oct 31, 2010 3:09 am
Yeah I have a manual...
My build: Click WWW
Post Posted: Sun Oct 31, 2010 3:41 am
swift pump has a different pully bolt pattern and will not allow for the engine fan. you would also need new pulleys as well.
Post Posted: Sun Oct 31, 2010 5:33 am
Yuck that...
My build: Click WWW
Post Posted: Sun Oct 31, 2010 5:43 am
as was mentioned 3 times earlier in this thread....
Post Posted: Mon Nov 01, 2010 9:54 am
swift 84-89 used the same pump as the sierra , and the pump in the pic is the same pump , its only 89 onwards swift pump that uses the larger flange.
Post Posted: Mon Nov 01, 2010 10:45 am
So... Will it fit or not? Hahah MIXED MESSAGES!!
My build: Click WWW
Post Posted: Mon Nov 01, 2010 7:22 pm
yes
Post Posted: Thu Nov 04, 2010 8:48 pm
Replacing a timing belt and water pump is a fairly straight forward job for those that know what they are doing, (easy for me I am a qualified mechanic)
However If you have no idea what you are doing in regards to timing belts, i would suggest you get a mechanic to do the job for you. Better safe than sorry.
1996 Vitara JLX 1.6 LWB (hunting truck) 235/75/R15
Vehicle: '94 suzuki maruti
Post Posted: Thu Nov 04, 2010 9:03 pm
need to ask more precisely :wink: will it fit without having to change anything else to suit the new pump such as new pulleys, etc etc...?
Post Posted: Mon Nov 08, 2010 10:17 am
Good to practise on :D Sierra engines are free spinning aren't they? No valves hitting pistons = good practise :)
Users browsing this forum: No registered users and 53 guests
