It is currently Wed Sep 30, 2026 2:32 pm
Post Posted: Sat Oct 30, 2010 1:55 am
Post Posted: Sat Oct 30, 2010 2:05 am
What about a collapsed king pin bearing? or even broken pin itself?
Clearance Hole Technology :P
Post Posted: Sat Oct 30, 2010 2:21 am
whats the easiest way to check? not very familiar with king pins etc.
Post Posted: Sat Oct 30, 2010 2:34 am
Whole wheel/ knuckle/hub will flop around
Jack her up and have a feel.
Id also check the box by itself, and the uni's/uni in the steering column shaft at the firewall. They can seize.
Post Posted: Sat Oct 30, 2010 2:47 am
will be the uni's in the steering shaft.
Post Posted: Sat Oct 30, 2010 3:02 am
Yes mine did that once.
Also steering box can do that, too, but more likely steering shaft unis.
I got by with spraying unis with wd40 type stuff for a few days
Post Posted: Sat Oct 30, 2010 3:05 am
dont forget that simex's tend to wander around abit on the road and they are a stickier compound than most tyres, they get stickier as they wear.
Maybe you need some lube/graphite grease in your steering box.
Post Posted: Sat Oct 30, 2010 3:21 am
My box did the same thing when it was dieing. It was like the gears werent meshing in it and so would lock up every now and then.
Post Posted: Sat Oct 30, 2010 3:27 am
If it is the sterring box it might be time for a p/s conversion :P
hmm interesting... i've jacked up the front end and can't find a thing wrong... made a vid while i was out there, here it is on youtube:
http://www.youtube.com/watch?v=sV_uSA6PLx4
http://www.suzistore.com.au/shopexd.asp?id=1822
steering uni aint cheap either!!! bugger.
Post Posted: Sat Oct 30, 2010 3:35 am
yeah i just inox'd all over the uni joint, no change at all.
its doing it more in just 1 spot, the spot shown in the vid, i just replicated it then after lots of left and right it suddely bound up again.
Post Posted: Sat Oct 30, 2010 3:38 am
u need to lube the box itself me thinks, i didnt have a grease gun so i just took of the top of the box and filled that sucka up with grease.
Post Posted: Sat Oct 30, 2010 3:40 am
so just drop off the 4 screws on the corners and pump it full?? what kinda grease?
As an aside - how much of a safety issue is a failling box or uni if thats what it is? ie: chances of losing steering altogether?
Post Posted: Sat Oct 30, 2010 3:53 am
I'd say thats what would happen
Post Posted: Sat Oct 30, 2010 4:14 am
hrm - lol i've undone all the nuts on the top plate and the dam thing wont come off!
Post Posted: Sat Oct 30, 2010 4:19 am
nevermind - hammer and screwdriver tapped it free...
now- the grease inside - is it supposed to be runny, feels like engine oil consistency but its browny murky coloured.
Post Posted: Sat Oct 30, 2010 4:59 am
ok - well inside the box only had 2mm of oil/grease - everything inside was oiled but there certainly wasnt an abundance of the stuff.
out of curiosity, what are you supposed to put in there via the filler hole?
going for a test drive shortly to see what difference adding a few glops of grease has made.
Post Posted: Sat Oct 30, 2010 5:12 am
ok - test drive complete... everything seems to be working as normal, no weird steering.
oddly, since spraying the uni with inox my squeaking steering wheel has stopped squeaking! thats kinda cool.
will update if the issue comes back.
Post Posted: Sat Oct 30, 2010 8:40 am
the steering box should have a gear oil in it (I think specifications recommend a 90 grade). it shouldn't have grease and it definately shouldn't be 'brown murky'.
from the fix of putting grease in making a difference you should pull the box apart, clean it all out and reassemble and fill with gear oil, while your at it replace the seals too.
Post Posted: Sat Oct 30, 2010 8:53 am
50/50 gear oil and grease was what I used in my Sierra steering box for years.
Post Posted: Sat Oct 30, 2010 9:08 am
cool - so how does one drain the oil from a steering box? lol
Post Posted: Sat Oct 30, 2010 9:20 am
I'm 99% sure you need to remove box to clean it and change its oil.
I never had to, just topped mine up.
Post Posted: Sat Oct 30, 2010 9:28 am
mmm i spose i can be lazy and top it up with gear oil for the time being - i dont like the idea of the brown oil though... lol
how far do you fill it with gear oil? all the way up to the filler screw or only a bit?
Post Posted: Sat Oct 30, 2010 9:32 am
I filled mine up, not sure if that is right, just it is what I did.
Post Posted: Sat Oct 30, 2010 9:37 am
got a large syringe & some small bong tubing?
Post Posted: Sat Oct 30, 2010 9:38 am
lol does anyone have a genuine manual that can confirm what oil and to what level??
mine only had about 2mm if that of oil in it when putting a screwdriver in next to the bit that holds the adjuster screw. i didnt get a good look deeper down but it was only just wet in there, not completely submersed in oil.
Post Posted: Sat Oct 30, 2010 9:56 am
downloaded the FSM from suzukiinfo.com - you're supposed to use SAE90 gear oil and fill it 35mm from the filler cap =)
this means that mine was low on oil, but given the grease i added should now be about right.
Post Posted: Sat Oct 30, 2010 9:58 am
Mine was overfull then :oops:
Tho it probably all leaked over time anyway :roll:
Post Posted: Sat Oct 30, 2010 10:01 am
cant be too bad - its a worm gear so its not like its going to froth up the oil, most likely just unneccessary to have the oil up there where theres no moving parts.
Post Posted: Sat Oct 30, 2010 11:33 am
Good time to buy a P/S box :D
Users browsing this forum: No registered users and 98 guests
