It is currently Wed Oct 28, 2026 12:45 am
Post Posted: Tue Nov 02, 2010 3:40 am
Hay all, I hope someone has some suggestions cause its getting annoying.
I have thing squeal like a slipping fan belt (and its not the fan belt) that starts around 2500rpm and disappears after 3000rpm in every gear, its driving me mad. The engine will be gone in a few weeks as i just picked up a G16. I just would like to beat this noise and find out what is causing it.
I have removed the cover over the exhaust manifold and there is a crack, could that be it????? I have a set of extractors for the new motor so no big issue there.
Vehicle: MY2019 Jimny
Post Posted: Tue Nov 02, 2010 3:45 am
Does it do it with the clutch in or out?
Post Posted: Tue Nov 02, 2010 3:49 am
both clutch in or out, it quietens a little when the clutch is in cause of no load on the engine, but its still there...... i have a new clutch for the new engine also.
Post Posted: Tue Nov 02, 2010 4:01 am
Thrust bearing maybe, dos the noise change according to revs?
Post Posted: Tue Nov 02, 2010 4:06 am
Very slightly, but also its only in about a range of 500rpm. I will try and record it, its dam loud also like a squealing fan belt.
Post Posted: Tue Nov 02, 2010 4:14 am
TIming belt?
Water pump?
Hard to say...
Post Posted: Tue Nov 02, 2010 4:18 am
I just recorded it on my phone, i will get it up loaded really soon. And before anyone says anything i do have the front tail shaft out at the moment cause its in my shed and im putting new uni's in
Post Posted: Tue Nov 02, 2010 4:24 am
Post Posted: Tue Nov 02, 2010 4:27 am
8O
Sounds like a thrust bearing to me, but I'm probably wrong.
Post Posted: Tue Nov 02, 2010 4:33 am
Thanks for your help, i will be changing it all in the next week when i drop in the new engine, clutch, exhaust, radiator and all my other goodies.
Also thanks for the rims i picked up off you a couple of weeks ago.
Post Posted: Tue Nov 02, 2010 4:54 am
Nurries!
Post Posted: Tue Nov 02, 2010 5:11 am
Sounds like something in the clutch to me.. Throw out or possibly the spigot bearing but that's just a guess.
Make sure to fit a new spigot bearing to the G16.. Many people overlook them and prematurely wear out the input shaft.
Post Posted: Tue Nov 02, 2010 5:24 am
yup got a new thrust bearing and the spiggot as well, my spare room is full of parts.
Vehicle: 91 SWB Softie Sierra
Post Posted: Tue Mar 29, 2011 8:33 am
Hey mate, i had the exact same same problem in my 91' sierra. extremely annoying noise at about 3000rpm, was stumped as to what it was...
Ended up being a bolt for the exhaust above the cat, that screws on to the bottom of your transmission. It was put on wrong and the spacer was rubbing on the metal of the bracket.
Post Posted: Tue Mar 29, 2011 10:26 am
Hay all funny thing was i found the noise. it was the shroud just after the cat, it had a crack in it and at that point in the revs the harmonics made it vibrate and squeel. I tore it off and all was good. Funny as hell that something simple like that caused me so much grief
Post Posted: Tue Mar 29, 2011 8:47 pm
I spent 2 weeks trying to find a noise,
different noise to yours, but mine was a loose bolt,
where cat bolts up.
We learn new shit everyday :)
Post Posted: Tue Mar 29, 2011 8:52 pm
I had a really strange noise once, just after I did a bunch of work on my starter motor.
I ended up pulling it out a few times, as well as checking everything else in the area. The noise persisted, and was semi-random.
A few days later, my e-tag fell off the windscreen, and the noise stopped. It was vibrating on the mirror.
Post Posted: Tue Mar 29, 2011 9:04 pm
hahaha thatt really goto piss you off^^
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Mar 29, 2011 9:06 pm
Yes and no...
I felt like a noob, but it meant there was no problem either!
Post Posted: Tue Mar 29, 2011 9:14 pm
yeh true
Post Posted: Wed Mar 30, 2011 7:42 am
there was a video doing the rounds of a guy with a rattle some where in his dash pulled everything apart then found some small nuts an bolts in his ash tray
Vehicle: Daisy
Post Posted: Wed Mar 30, 2011 8:46 am
It's a supercheap auto advertisement isn't it?
Oh and it's the mrs earrings in the ashtray.
Post Posted: Wed Mar 30, 2011 9:35 am
He was looking for the rings couldn't find them anywhere dismantled the whole car then opened the coin tray and there they were. Yep super cheap ad.
Users browsing this forum: No registered users and 402 guests
