It is currently Wed Jul 29, 2026 1:43 pm
Post Posted: Wed Nov 03, 2010 7:58 am
Can anyone shed any light on why my bottom leaves look as they do. Havn't seen any like it before and havn't had time to get to the spring specialists yet and am curious as to why it maybe.
Cheers Matt.
Post Posted: Wed Nov 03, 2010 8:11 am
The bottom one is the load spring & is meant to be straight, yours have been over loaded..
cause there rooted, get some new ones.
Post Posted: Wed Nov 03, 2010 8:20 am
Thanks gents.
I knew the load bearers were meant to be flat but hadn't thought thats what they were and might have been overloaded. Will be getting some lifted jobbies down the track so will just keep it going till then.
Post Posted: Wed Nov 03, 2010 8:33 am
All WT's I have seen (standard) looked like that. I wonder if there was a strange batch of springs made :?
Clearance Hole Technology :P
Post Posted: Wed Nov 03, 2010 10:01 am
i think its more like they have done 250,000kms and are 20+ yrs old
Post Posted: Wed Nov 03, 2010 10:04 am
they hang down stoopid low and get you hung up on logs :lol:
Member of C.O.R 4x4
Post Posted: Wed Nov 03, 2010 12:03 pm
Yes id agree with you there! Maybe the idea behind them is to try and give some sort of progressive spring loading once the pack starts to come in contact with them? :?
Lil Foot!
Post Posted: Thu Nov 04, 2010 8:43 am
Yep spot on! my bottom ones actually snapped at the centre bolt on my epic mission due to being grossly overloaded!
GTi Turbo & A LWB Sierra.
Post Posted: Thu Nov 04, 2010 8:57 am
Well I spoke to the spring guru in town and he thinks they have neen put upside down as it was too stiff the other way and done as not to have to replace the u bolts. Its a 94 WT Softtop with 164000 on the clock. So buggered if I know really.
Post Posted: Thu Nov 04, 2010 9:46 am
i have a 95 soft top and mine look the same if not worse the end of the load leaf is around 50-60mm from the rest of the spring pack getting some new ones soon so i hope they don't fail in the mean time
Post Posted: Thu Nov 04, 2010 9:48 am
looking at the gaps between the leafs they look like they've had a bit of a hard time.
Post Posted: Thu Nov 04, 2010 10:28 am
:? 8O
Post Posted: Thu Nov 04, 2010 8:07 pm
Exactly
Theres no marks etc on the top of the bottom leaf either where it might have come in contact with the others either. :?
Post Posted: Fri Nov 05, 2010 7:05 am
I can see the bent main in the pic's, from the load leaf...
If he's a "guru", well................................ 8O
Users browsing this forum: Google [Bot] and 510 guests
