It is currently Wed Nov 04, 2026 9:01 pm
Post new topic Reply to topic  [ 130 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Post Posted: Wed Oct 27, 2010 11:16 am
i edited my previous post after i read what you said. I'm not really sure, i am pretty sure a relay will lower the voltage drop from the battery to the lights which will give you better light. No its not essential but i believe it will be beneficial, and i'm sure someone can explain it much better than I.
Post Posted: Wed Oct 27, 2010 11:18 am
Ok.. Well I will wait till the morning then :)
My build: Click WWW
Post Posted: Wed Oct 27, 2010 7:29 pm
you still need a relay, a relay copes with switching the load better than a switch and keeps all the high current wiring under the bonnet
Post Posted: Wed Nov 10, 2010 8:53 am
i remember when this buggered me up bad when i got my zuk :lol: :lol:
in normal situation you would have 30 to + on battery
87(s) out to your lights or accessories
85 earth
86 trigger off hi beam or accessorie or whatever you want to activate from
85 and 86 will both be earth until you switch on hi beam when 86 would then become powered and switching to power lights at 87
but in a zook the lights wire will be powered at all times until it become activated(switch to hibeam) and then it becomes earth so you have 2 earths and the relay wont switch.To beat this 85 gets looped around and doubled up on 30 of the relay giving it power.
Thats how my spotties are done on mine and then my thermo fan and rocklights are done under the other method
Post Posted: Tue Jan 04, 2011 10:35 am
Having searched and read all the topics on spotlight connections - could someone please answer this question to ensure I don't stuff it up? I have spots with wiring harness. It says "to connect to High Beam, locate the High Beam Cable for headlights". Is this the wire that comes from the right side of headlights looking from the back as stated in (excellent) posts on this forum? I am just confused as to all the talk of the "different" wiring of Suzuki's. BTW, it's for a '88 Sierra - again not sure whether all Suzuki's are the same in this regard. Cheers for any help.
Post Posted: Tue Jan 04, 2011 10:41 am
yes, but the wire from the relay that goes to earth (not the earth for the lights) needs to go to the left pin as well :)
Post Posted: Tue Jan 04, 2011 10:52 am
Royce, thanks for that! :D You (and the "know-how guys on the forume are stars! Cheers!
Post Posted: Sat Jan 15, 2011 4:50 am
And a follow up question. Do I need to connect the corresponding wires (as in previous post) to both headlights, or can I just join to the drivers side left and right pins, as I assume from there they are connected to the other headlight in any case.
Vehicle: LPG 1.6 Sierra
Post Posted: Mon Jan 24, 2011 10:42 pm
I'll post this in here as an FYI. This is a diagram for upgrading headlight wiring, powered directly from the battery. You can use either left or right hand side headlight socket to run from. It shouldn't matter.
I did it to mine a few days ago now, and lighting is now 1000x better :)
Make the red wires 6mm, the rest can be 4mm.
Post Posted: Wed Feb 09, 2011 10:10 pm
If anyone has mounted their spotties off a roofrack, how are you running the wiring?
Vehicle: 2001 Jimny M13A
Post Posted: Tue Apr 12, 2011 4:18 am
I'm giving the fully relayed headlights and spotlight (LED light bar) wiring a go. :) But have some noob questions, so it's all clear in my head for stock Jimny!!
1: is this correct?
LOW BEAM RELAY switch
White(red stripe) wire to 85, Red (white stripe) wire to 86
HIGH BEAM RELAY switch
White (red stripe) wire to 85, RED wire to 86
or
2: this way?
RED wire to 85,
RED wire to 85,
White (red stripe) wire to 86
3: What type of Relay protection recommended (for Normally Open)?
a: No protection
b: Fuse protection
c: Resistor protection
d: Diode protection
e: doesn't matter
Thanks in advance :wink:
Post Posted: Tue Apr 12, 2011 4:56 am
dont bother with wire colours, go with position into teh plug
unplug both headlights, from one headlight, the vertical pin that has power on it, goes to 86 on both releays
the other vertical pin goes to 85 on high beam, the horizontal to 85 on low beam
Post Posted: Wed Apr 13, 2011 3:45 am
Cheers Royce
Is this with High beam on or with every thing off?
Post Posted: Wed Apr 13, 2011 4:06 am
everything off, both headlights unplugged
Post Posted: Wed Apr 13, 2011 4:35 am
So is this the right way Royce?
Thanks again.
Post Posted: Wed Apr 13, 2011 5:12 am
I dont get your table cause ground is the only terminal should show power
I would have a seperate fuse into each pin 30, so if something happens on a dark road and you blow the fuse you can flick to the other beam to avoid running into something
You could also tap pin 86 from pin 30 on each relay so you no longer have to worry about teh stock power supply at all, I have not tried this before but will on the looms I make
Post Posted: Wed Apr 13, 2011 5:25 am
No worries Royce.
I've tested the results in the table a couple of times now with a dodgy cheap multimeter and a test light (black dot and star things).
So either my lights are going to stay on for a couple of hours when off.
Or somethings up with the stock wiring?
Not easy hay.
Post Posted: Wed Apr 13, 2011 5:50 am
Fault finding time :lol:
Same results on left H4 plug. So i guess it must be somewhere further back.
Another solution maybe to have one more relay just after the fuse from battery, triggered by ...............no that won't work!! as i will still have lights on with park and ignition on. :crazy:
Post Posted: Wed Apr 13, 2011 5:54 am
You have both headlights unplugged at teh same time yeah?
dont worry about when it has power, it always will do, if you look at the pass and drive wires, one will show circuit to earth on low and the other on high and open circuit otherwise, both should also show open circuit when the headlights are off
Post Posted: Wed Apr 13, 2011 6:35 am
This is what I do, much neater IMO
Post Posted: Wed Apr 13, 2011 6:37 am
Yep both unplugged or cut and isolated in my case.
I'm the third owner of this one and their was lots evidence of bodged spotlight fitting. :roll: :wink:
Fitted Narva H4 plugs on lights to replace stock, stock H4 plugs cut off and insulated blade terminals fitted to connect switch wires to relays.
note only relay switch circuit active (power circuit unplugged at lights) and when done as in above diagram 15amp headlight fuse is ok when on park or ignition on,
but then blows as soon as light is turned on l with low or high.
Run out of 15amp fuses but have a couple 20amps and a fire extinguisher.
Post Posted: Wed Apr 13, 2011 8:21 am
Returned the above to stockish again. The headlight fuse doesn't go pop now. :D
Ripped the neat relayed headlight/spotlight loom out for rethink and maybe some extra mods.
Any bright ideas welcome. :wink:
Post Posted: Wed Apr 13, 2011 10:45 am
have you ever come across anything that switches earth for high and low but positive to turn the lights on? I am sure some Toyotas did it
Post Posted: Wed Apr 13, 2011 1:12 pm
Just had a thought :blink:
could you get rid of two of the normally switched relays for the low and high and replace them with one change over relay?
Hooking the 87 to Low and 87a to high.
85 and 86 to pass and ground.
Post Posted: Wed Apr 13, 2011 1:16 pm
Then wont you get either low or high on and no off at all...
Lil Foot!
Post Posted: Wed Apr 13, 2011 1:24 pm
Don't know :D
I will try to get one tomorrow and have a play.
Post Posted: Wed Apr 13, 2011 1:32 pm
So the lights work how they are supposed to in the stock configuration? IF so then your table doesn't make sense and maybe you are measuring it wrong somehow :? .
Another thing that you may just wanna clear up so it doesnt cause any confusion is your terminal name 'ground' change this to 'common' as it relates to the common connection within the headlight bulb.
With the measurements in the table common will always be ~12V so it should measure something like this if your headlights do actually work properly in your stock configuration.
Measured from the plug, both plugs undone:
Common - Low - high
OFF: 12V - 12V - 12V
Low: 12V - 0V - 12V
High: 12V - 12V -0V
Pass/dip:12V -0V -0V
Hope it helps
Lil Foot!
Post Posted: Wed Apr 13, 2011 2:26 pm
Common - Low - high
Low: 12V - 0V - 12V
High: 12V - 12V -0V
Hope it helps
Cheers, i fully agree, the table result wasn't what i expected but what you show is.
I called it ground instead of common as thats what on the stock plug, the narva plug calls it common, but easily changed on drawing. I tend to draw what i see hay.
Have you tested the above?
thanks heaps for your help hay. :D
Vehicle: '94 suzuki maruti
Post Posted: Wed Apr 13, 2011 7:50 pm
i started doing this yesterday, got halfway through and realised i didnt have enough of those little blade things that join the wire to the relay (whatever the name is) :oops: , but im getting photos of everything, i can do a bit of a step-by-step guide if anyones interested...
Post Posted: Wed Apr 13, 2011 10:53 pm
if your headlights are unplugged you will never see voltage on anything but the common terminal.
You will if you have the lights plugged in or there is still a relay in the circuit somewhere, this is why I also hate multimeters for working out live wires in cars, you look like you have power there but you are seeing it through a bulb or relay somewhere
Users browsing this forum: No registered users and 14 guests
