It is currently Mon Nov 02, 2026 6:17 am
Post Posted: Fri Nov 12, 2010 3:33 am
Just changed my fuel pump and fuel filter Nevada car would turn over but wouldn't start has spark. But still won't start any suggestions on what it may be or how i can check the pump is pumping fuel?
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Fri Nov 12, 2010 3:34 am
pull the output line off the pump.....
wheelin :)
Post Posted: Fri Nov 12, 2010 3:35 am
ohhh and try to start it. make sure u pull ur coil lead off too and point the output line to the ground..
wheelin :)
Post Posted: Fri Nov 12, 2010 3:39 am
did u check the pump before fitment???
wheelin :)
Post Posted: Fri Nov 12, 2010 3:51 am
is the fuel pump pumping fuel, if not make sure you have that shaft/pin in place that moves the fuel pump arm. sorry if this is hard to understand
Post Posted: Fri Nov 12, 2010 3:52 am
He doesn't know, he's asking us how to tell if its pumping :roll:
I want my old sig back :(
Post Posted: Fri Nov 12, 2010 3:53 am
woops my bad :? well if he finds out its not pumping then check the pin
Vehicle: 75 Cruiser
Post Posted: Fri Nov 12, 2010 3:55 am
is it carby or efi? Did you put the pump around the right way? What's a Nevada car?
yeah pull the line off and turn the key and see if it pumps out all over your engine. (maybe point it away ) :wink:
Post Posted: Fri Nov 12, 2010 3:56 am
If its not an EFI pump :wink:
Lil Foot!
Post Posted: Fri Nov 12, 2010 3:57 am
Its injected yeah?
stick a test light into teh power plug at teh tank end, youll need somebody to crank while you watch to see if you have power there (ecu only powers it while the engine is turning more or less)
if you have power you should be able to hear the pump whir if you stick your ear to teh tank, if you dont, start at the fuse and see if you can hear the relay clicking above the accelorator pedal
it will take a while to prime and get up to pressure but not long enough to think something is wrong
Post Posted: Fri Nov 12, 2010 3:58 am
the pins dont normally just fall out but you never know. btw the pin is in the head and will move out slightly etc etc. let us know how u go.
wheelin :)
Post Posted: Fri Nov 12, 2010 4:00 am
o could be efi too good point.... you will hear the pump priming also.... kick the tank too.....
wheelin :)
if its efi then theres no pin cos the pump is attach to the tank not the head?
Post Posted: Fri Nov 12, 2010 4:01 am
agreeded
wheelin :)
Vehicle: 75 Cruiser
Why can't ya do that? :oops:
Post Posted: Fri Nov 12, 2010 4:03 am
too much pressure, you can but yeah not recommoded
wheelin :)
Vehicle: 75 Cruiser
Post Posted: Fri Nov 12, 2010 4:05 am
ahh is that all, well too late anyway :lol:
Post Posted: Fri Nov 12, 2010 4:06 am
there is no ppressure if its jsut dribbling out a hose
anyway with injected you jsut pull the bung on teh front of the rail and let it spew all over the radiator :)
Post Posted: Fri Nov 12, 2010 4:11 am
so whats the go? any test tried? ?? got it started yet?
wheelin :)
Post Posted: Fri Nov 12, 2010 4:12 am
id say faulty pump or fitment error (fuse blow etc etc)
wheelin :)
Post Posted: Fri Nov 12, 2010 4:13 am
I am aiming towards an electrical problem making the old pump stop to begin with :)
Post Posted: Fri Nov 12, 2010 4:16 am
good point... fuse, shit contacts on pump.. earth problem,
is the car standard engne ecu etc?
wheelin :)
Post Posted: Fri Nov 12, 2010 4:20 am
or he has fixed it and has'nt told us, and is now out wheeling the crap out f his car :lol:
Post Posted: Fri Nov 12, 2010 4:23 am
mmm bastard....
wheelin :)
Post Posted: Fri Nov 12, 2010 5:02 am
Well fuses are all good but pump isn't whirling or anything must be electrical just has to figure out where the problem is
Post Posted: Fri Nov 12, 2010 5:09 am
test light, check for power at the pump and work forward, the fuel pump relay might be the green plug, cant remember
Post Posted: Fri Nov 12, 2010 5:15 am
As royce said. Look for the fuel pump relay. I can't remember if it has the green plug or not, but it does have 2 or 3 pink wires leading into it.
If you can't here is clicking on and off to let the fuel pump prime, then something is amiss with the relay.
Users browsing this forum: Google [Bot] and 123 guests
