It is currently Mon Oct 12, 2026 11:40 pm
Post Posted: Mon Nov 15, 2010 5:49 am
hey guys
ive looked on here and outer limits and cannot find any confident information about putting a g13b (carby 8v) head on a g16a (efi 16v) engine numbers might not be corret but thats what they say on the blocks
the 1.3 is carby and the 1.6 is efi
i have a stock 1.3 in the zook atm 91'
and a 1.6 efi on the floor.
will the 1.3 head bolt straight up and run with all gear "as is"
without changing pistons (so they wont hit the valves)
changing valves
i know ill need bellhousing adaptor and engine mount adaptor kit etc etc
also starter motor adapting and alternator etc and to use the 1.3lt clutch and what ever
so will the head bolt up and is it worth it over the 1.3 block ?
thanks guys
wheelin :)
Post Posted: Mon Nov 15, 2010 5:55 am
What's stopping you fitting the efi??
should bolt up, but when you have a better option, why not use it..
Post Posted: Mon Nov 15, 2010 5:57 am
nothing atm im getting the head pressure tested tomorrow cause she over heated thats why i got it cheap as.
if the heads Fu#kd then i was thinkin that
if the heads ok ill prob go efi
just checkin what the go is
wheelin :)
Post Posted: Mon Nov 15, 2010 6:02 am
That's the go..
They bolt up, but something about cam belt ring's a bell, can't remember which to use..
here's hoping the efi head's good.. :P
Post Posted: Mon Nov 15, 2010 6:04 am
yep :) i hope so too.
still bit worried bout the vss i will need if / wen i go efi
wheelin :)
Post Posted: Mon Nov 15, 2010 6:07 am
Do you have the vit speedo head?? It's an easy swap over, almost as if it was ment to fit..
If not Jrzook has done a write up on em in fab, make your own.. :D
Post Posted: Mon Nov 15, 2010 6:08 am
ummm how do i tell?
so i mite not need vss?
wheelin :)
Post Posted: Mon Nov 15, 2010 7:06 am
vss is easy, too easy, i made my own gear out of a jaycar catalogue....
Vehicle: 85 SJ413
Post Posted: Mon Nov 15, 2010 8:01 am
Yeah, the cam belts are different widths, and the tooth profile is square on one and round on the other.
Should be able to fix by swapping timing pulleys on the crank. Just make sure its done back up REALLY tight as per the factory spec so it doesn't come loose and f*ck the crank keyway.
Oh, and click the www link in my sig for a 1600 adaptor kit :D
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Mon Nov 15, 2010 8:08 am
i have g13ba head on a g16a block. use the biggest timing belt, not sure wich one
Users browsing this forum: No registered users and 232 guests
