It is currently Tue Oct 13, 2026 3:25 pm
Vehicle: 2018 DMAX
Post Posted: Mon Nov 15, 2010 1:36 am
Went out for a wheel other the weekend, went good for a few hours and then just started stalling, i couldnt get the revs up much either. So I turned the idle up and limped it home
Its blowing alot of unburnt fuel out the exhuast and the plugs are black. With he idle turned upto around 2k it doesnt stall, revs cut out at around 3k. If you stab the throttle it back fires and shots foot long flames out the back. Any ideas what could be causing it to over fuel??
http://www.youtube.com/watch?v=To85WHFclBg
Post Posted: Mon Nov 15, 2010 3:01 am
do you have an eng light hooked up??
Vehicle: 2018 DMAX
Post Posted: Mon Nov 15, 2010 3:24 am
Hooked up but im not sure if its working right... Will it flash a code to say theres nothing wrong?
Post Posted: Mon Nov 15, 2010 3:31 am
It should flash 12, that 1 pulse, short gap 2 pulse's..
That's system pass..
Vehicle: 2018 DMAX
Post Posted: Mon Nov 15, 2010 4:10 am
Hmmm engine light doesnt work then.. Its hooked up correct but no go..
Post Posted: Mon Nov 15, 2010 8:02 am
Hows it hooked up? +12V to light then light to ECU? Overfuelling? Almost sounds like a misfire
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Mon Nov 15, 2010 10:44 am
Yer gonna double check it tomorrow, certain thats how its hooked up tho. The ecu is damaged, the fuel pump cant be run off it. Is possible some other circuits dont work. Definatly overfueling, enough fuel comeing out the exhuast to keep the locles going all night. You can hear it backfire at the start and end of that video...
Vehicle: 2018 DMAX
Post Posted: Mon Nov 29, 2010 9:49 am
Ok, had more of a play with it. The ecu wont show any codes. I tried fuel reg but thats fine. Tried starting it before and I now have no spark. No power showing at the lead running into the coil.
Would a weak spark cause the above symptoms?
Post Posted: Mon Nov 29, 2010 10:03 am
could be the throttle positioning sensor, if its a g13b
mine was doing the same as your, unplugged it and its fine.
chasing a new 1 at the moment
dodgy brothers mechanical
Post Posted: Mon Nov 29, 2010 2:35 pm
Running pig rich & rev limited to 3k rpms are indications that you have a failed ECU in limp home mode
Vehicle: Vitara 90'
Post Posted: Tue Nov 30, 2010 12:34 am
Maybe MAF sensor? .02c :D
Vehicle: 2018 DMAX
Post Posted: Tue Nov 30, 2010 9:05 am
Im thinking what fordem said.. This ecu already has issues(wont run the fuel pump). I tried to work out why it has no spark today, and it looks like the coil isnt even getting a pulse from the ecu.. So i think i need to find a new ecu, or atleast borrow one from someone and see if that works.
MAF is working as far as I can tell..
/just checked the diagram, and the coil runs thru the igniter. So maybe thats broken.. Anyone know how to test them?
Post Posted: Tue Nov 30, 2010 9:15 am
I was hoping that the movie was the flames out the exhaust ;)
My Maruti build, Click WWW
Post Posted: Tue Nov 30, 2010 9:31 am
http://auszookers.com/index.php?name=Yo ... profile=78
Dan has an ecu, but I think it may be in bit's by now..
Vehicle: 2018 DMAX
Post Posted: Tue Nov 30, 2010 9:42 am
Hmm, I have to test this bloody igniter somehow before i try an ecu.. If the igniter works, then i can be certain the ecu has issues.
Post Posted: Tue Nov 30, 2010 10:42 am
steak_knife wrote:
http://auszookers.com/index.php?name=Your_Account&profile=78
Hasn't been violated yet!!! OP what ECU is yours? Are you running the hot wire MAF or earlier cone style mechanical one?
Dan
Lil Foot!
Post Posted: Tue Nov 30, 2010 12:40 pm
Dan
:wink:
Vehicle: 2018 DMAX
Post Posted: Wed Dec 01, 2010 8:27 am
^^^ Yer cone style, some one had a few cones when they designed it I think..
JrZook, whats the chances of borrowing that ecu for a day.. alcoholic incentives
Users browsing this forum: Google [Bot] and 188 guests
