It is currently Mon Oct 12, 2026 6:00 pm
Post Posted: Mon Nov 15, 2010 5:17 am
i've done some searching but couldnt find anything really.
i rebuilt by carby on the weekend and the only problem i have is it runs like crap when its cold. starts easy, idles at like 2k when its cold with the auto choke but splutters and has no power till it warms up. once its warm drives good as again, any one have any ideas
Post Posted: Mon Nov 15, 2010 8:57 am
Search auto choke adjustment, all the info you need.
Post Posted: Mon Nov 15, 2010 8:59 am
http://auszookers.com/index.php?name=Fo ... adjustment
:P
Post Posted: Mon Nov 15, 2010 9:01 am
Found this to..
ok to set the choke
with engine cold and the intake hat off, the flap should be closed, look at the little gear type linkage on the side that actuates it and you will see 2 lines, they should line up, if not the tension is wrong, to set that look round the back/side of the carb where the water hoses connect and you will see a screw sticking out of a cylindrical chamber, turn that till they line up, now the amount of choke and time it stays on should be right
next the fast idle speed, have a good look at the throttle linkage and down out of the way youll see a screw you cant get at unless you are holding the throttle full open, thats the fast idle, to set hold the throttle open and screw it in a bit, let it go and start it up and see, I guess you want 1000-1200 rpm.
should be all good then, before doing this when the engine is up to temp check both water hoses into the carb are hot, otherwise there is a blockage and the choke will never turn off
Post Posted: Mon Nov 15, 2010 9:30 am
Thanks for that, had a bit off a look before and was starting to think it had something to do with the auto choke spring thingo, will have a look in the morning when its cold
Users browsing this forum: No registered users and 253 guests
