It is currently Tue Oct 06, 2026 8:52 pm
Post Posted: Tue Nov 16, 2010 3:10 am
once again there is a issue with my car. ive searched the forums but no posts regarding this issue:
after running 14* of timming running on 98 octane fuel ( has been running like that for 3 weeks ish) i was on the beach and it started to ping a little
then after that its been backfiring on deceleration and sometimes (normally when hot) not idling properly.... ive noticed the carby plunger not as freely moving as normal but yeah
ive back the timing back to 8* and its still doing this
any ideas?????
ive had the carb adjustd but still noo good...
wheelin :)
Post Posted: Tue Nov 16, 2010 3:22 am
Strip the carby down and cleane it, blow out the jets, clean or replace your plugs, probably got crap in the carby, try that ,will probably
fix ur idle problem, also clean the points under the dizzy cap
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Tue Nov 16, 2010 3:31 am
carby was done a month ago and i have cleaned jets and fuel etc etc. doesnt have points bruz electronic ign here :)
wheelin :)
Post Posted: Tue Nov 16, 2010 3:32 am
im thinking the timing belt has jumped a tooth and the plunger has become sticky..... opinions?
wheelin :)
Post Posted: Tue Nov 16, 2010 3:39 am
What motor you Running???
Post Posted: Tue Nov 16, 2010 3:44 am
g13b on rego papers but i think its a g13a 1.3 sohc carby snot box in a 1991 sierra has no points cause when i did the rotor button and cap... :) i was like woop woop
wheelin :)
Post Posted: Tue Nov 16, 2010 3:59 am
Ha nice, yeah, your probably on the ball, strip the timing gear cover and check timing belt hasn't jumped a tooth, otherwise without laying a spanner or listining to it probably can't help ya too much more
Users browsing this forum: Google [Bot] and 205 guests
