It is currently Wed Sep 30, 2026 4:32 am
Post Posted: Fri Nov 19, 2010 10:00 am
G'Day guys after searching and searching for ages for a 1L motor for my sj40t i am to the point of giving up
I have a 1.3L carb motor out of a 85? barina approx that i am thinking about using. Can anyone point me in the right direction of what gearbox i should be looking for as I am fairly sure it wont bolt upto the 1L four speed
any help would be appreciated, i have used the seach button many times but have no solid answers, sorry
thanks matt
Post Posted: Fri Nov 19, 2010 10:02 am
1.3 sierra box, but you will need to run a sierra cam & dizzy to clear the firewall, some other thing's to, but escape me ATM...
Post Posted: Fri Nov 19, 2010 10:13 am
So if i got a 1.3L sierra head and bolted it on with the dizzy and shit then a 1.3L seirra box would just bolt up to the motor correct.. does it matter from what year the box and head are from or just the 1.3 L ones?
Would the motor pretty much drop in then? or do you need to weld the engine mounts to the chassis of the sj etc?
Post Posted: Fri Nov 19, 2010 10:43 am
Yes to eng mount's, the lt one's are different to 1.3..
you would be better off getting a complete 1.3 & box, cause the manifold's are different to..
Wiring for the eng & alt are different..
More thing's will come to me.. :roll:
Post Posted: Fri Nov 19, 2010 10:49 am
radiator mount's... :wink:
More will come....
G/box mount to.. :lol:
Anyone else want to help?? :lol:
Post Posted: Fri Nov 19, 2010 10:53 am
gearbox tunnel needs a bash if no body lift., you can just use two pices of 10mm plate insted of welding engine mounts. But you have to modify the gearbox mounts anyways so might aswell do it properly.
You will need a lot of things from a 1.3L might be better to try and find a 1.3 chassis.
Give this a read.
http://www.outerlimits4x4.com/viewtopic.php?t=37821
My Maruti build, Click WWW
Post Posted: Fri Nov 19, 2010 10:58 am
xedent wrote:
:P OOOoo, log in board... :P
Post Posted: Fri Nov 19, 2010 11:28 am
steak_knife wrote:
click in once and log in then click it again, works for me.
Post Posted: Fri Nov 19, 2010 11:34 am
Off the top of my head you need:
1.3 Gearbox
1.3 Engine mounts
1.3 Sierra Water pump (can use barina pump but you will need a thermo)
1.3 Sierra engine fan (can use thermo as above)
1.3 Carby (Barina one has a whole lot of shit on it that is not helpful)
1.3 Inlet and Exhaust manifolds
1.3 Sierra cam and distributor (or whole Sierra head)
1.3 Sierra fuel pump or electric fuel pump (Barina is electric but whole is in the head for the Sierra pump)
1.3 Accelerator cable (I think the Barina one was a lot longer, not 100% sure on this one)
Use the Barina alternator as it is a ~55amp unit which is much better than the stock sierra one. And as said above you will have to do some wiring.
Post Posted: Fri Nov 19, 2010 11:44 am
xedent wrote:
:roll: Not a member..
Post Posted: Fri Nov 19, 2010 11:46 am
http://auszookers.com/index.php?name=Fo ... 76&start=0
He has some pic's of what you will need to do for the alt wiring under the dash..
Vehicle: jimny
Post Posted: Fri Nov 19, 2010 5:57 pm
thanks matt
why not do the g16 efi engine, it really is only a little more work
Post Posted: Fri Nov 19, 2010 8:25 pm
Sump (& pickup) too.
Users browsing this forum: No registered users and 154 guests
