It is currently Sun Oct 11, 2026 12:03 pm
Vehicle: Sierra Ute '87 Sj70
Post Posted: Wed Dec 01, 2010 6:37 am
what are all the diff ratio's that will fit in a sierra wt 89 model
doing a centre swap cause its like reduction gears
Post Posted: Wed Dec 01, 2010 6:50 am
Easiest and most available is the NT 3.9 centers. What tyres do you run? Unless there excessivily big transfercase gears are the way to go both on/off road
Lil Foot!
It's nothing like fitting reduction gears. But better than nothing.
Post Posted: Wed Dec 01, 2010 7:30 am
bout to ru 30's have worked out need 4.1:1 ratio what diff centers are these?
i allready know that 1lt diffs fit
but i cant find any anywere
It's all coming together Armsup
Post Posted: Wed Dec 01, 2010 7:38 am
suzi-fan-22 wrote:
what are all the diff ratio's that will fit in a sierra wt 89 model?
bout to run 30's have worked out need 4.1:1 ratio.
If you know that 1.0lt diffs will fit in your 89 WT, then it's no point anyone on here telling you THEY WON'T!
If you think swapping diffs are just like fitting reduction gears (only more expensive and less effective), then you shouldn't consider 4.16 gears (1.580 Hi, 4.16 Lo). Put those figures in your calculator compared to 4.11 diffs.
Post Posted: Wed Dec 01, 2010 7:39 am
1 ltr diffs dont fit only the rare maruti wide track 4.1 centers fit.
you can fit front vitara gears they come in 4.6 and 5.12 not sure but i think thers 4.8 aswell
Post Posted: Wed Dec 01, 2010 7:44 am
Diff gears are nothingnothingnothing like transfer gears.
Diff gears can be used for correcting a tyre size on road, but will add very little to your off road gearing.
You can use 4.1 diff gears in a WT sierra, from the rear of a jimny ( which are apparently made from glass) or a late model Maruti (apparently)
But you don't want to. You want 4.1 transfer gears. Leave your diffs stock.
Post Posted: Wed Dec 01, 2010 8:13 am
righto great advise from EVERYONE thanks!
decided to go for 4.16:1 reduction gears
but how much and where from just some guesstamtions or rough figures would be great.
i live in ipswich QLD so just anywhere close to that would be lovely
thanks! heaps
Post Posted: Wed Dec 01, 2010 8:17 am
Lowrange Offroad will post to your door. Just ask for cheapest shipping option, takes about a week to 10 days.
Post Posted: Wed Dec 01, 2010 8:37 am
fuck you dribble shit a lot of the time.
diff gears will correct on road gearing and give you heaps better off road gearing too, not as much as t/case gears gears but plenty enough for you to drive off road with confidence. diff gears also don't have a tendancy to shag t case mounts out and other driveline components in a hurry.
Post Posted: Wed Dec 01, 2010 8:39 am
Post Posted: Wed Dec 01, 2010 10:06 am
Lets look at some figures.
Speed @ peak torque in 1st low with 26's and stock diff gears = 13.18km/h
Speed @ peak torque in 1st low with 30's and 4.1 diff gears = 15.2km/h
Cruise revs 26" tyres, 3.7diff gears, 100km/h, 5th= 3475rpm
Cruise revs with 30's, 4.1 diff gears, 100km/h, 5th= 3337rpm
So a sierra with 4.1's in the diffs and 30's is taller geared both on and off road than stock. That's not really an improvement in my opinion.
The next available next diff gear step is 4.3
@ peak torque in 1st low with 30's and 4.1 diff gears, speed = 14.5km/hr
Cruise revs with 30's, 4.3 diff gears, 100km/h, 5th= 3500rpm
Gearing is still taller off road, but spot on on road.
Above that, it's diminishing returns for off road performance.
Just to prove the point:
4.6 diff gears,
@ peak torque in 1st low with 30's and 4.6 diff gears, speed = 13.55km/hr
Cruise revs with 30's, 4.6 diff gears, 100km/h, 5th= 3744rpm
4.88 diff gears
@ peak torque in 1st low with 30's and 4.88 diff gears, speed = 12.77km/hr
Cruise revs with 30's, 4.88 diff gears, 100km/h, 5th= 3972rpm
and finally, 5.12
@ peak torque in 1st low with 30's and 5.12 diff gears, speed = 12.17km/hr
Cruise revs with 30's, 4.88 diff gears, 100km/h, 5th= 4168rpm
I don't think diff gears are a good way of improving off road gearing, and that's why. To gain slightly improved off road gearing once tyres are taken into account, your cruise revs are murdered, and car becomes less useable.
Anyway, to compare with stock diffs and 4.1 transfer gears:
Speed @ peak torque in 1st low with 30's and 4.1 transfer gears = 9.08km/h
Cruise revs with 30's, 4.1 transfer gears, stock diff gears 100km/h, 5th= 3313rpm
You be the judge of where the money is better spent.
Never mind though, I'm just dribbling shit.
Post Posted: Fri Dec 03, 2010 6:05 am
4.6 diff gears,
4.88 diff gears
and finally, 5.12
i worked out that the 30'' tyres where going to take my high range up 12% and the thats the same as 4.16 t/ gears and i put the tyres on with no gear changes and it takes off the same just the speedo is out and the brakes dont work as good but there is more grip and the steering is lighter
Post Posted: Fri Dec 03, 2010 6:26 am
What does that mean suzi-fan?
Post Posted: Fri Dec 03, 2010 6:42 am
he said soup's up.. :roll:
Post Posted: Sat Dec 04, 2010 2:28 am
[quote="suzi-fan-22] i worked out that the 30'' tyres where going to take my high range up 12% and the thats the same as 4.16 t/ gears and i put the tyres on with no gear changes and it takes off the same just the speedo is out and the brakes dont work as good but there is more grip and the steering is lighter[/quote]
That's the other advantage of transfer gears over diff gears, your speedo will be corrected by the same amount in both Hi and Lo ratios, whereas diff gears won't correct your speedo.
Post Posted: Sat Dec 04, 2010 2:36 am
i changed my diff ratio's from 4.6 to 5.1 & it fixed my speedo in both hi & low range?
Post Posted: Sat Dec 04, 2010 3:58 am
That's the other advantage of transfer gears over diff gears, your speedo will be corrected by the same amount in both Hi and Lo ratios, whereas diff gears won't correct your speedo.[/quote]
:rofl:
How?
Transfercase gears will not correct your speedo. The relationship between the tailshaft and axles is not altered with transfer case gears. It is only altered by changing diff ratios.
SS
Post Posted: Sat Dec 04, 2010 4:03 am
Ah ha. Proof. Wheel circumference must have been 11% larger. :)
SS
Post Posted: Sat Dec 04, 2010 4:31 am
stock was a 215/65/r16 (27's) & i'm now on 31's & my speedo is spot on.
Post Posted: Sat Dec 04, 2010 4:42 am
Thats a 14.8% change in true wheel circumference so if you take into account the little flat bit at the bottom of the tyre sounds like it would be pretty close to fixing it up nicely. :wink:
SS
Post Posted: Sat Dec 04, 2010 5:29 am
:rofl:
How?
Transfercase gears will not correct your speedo. [/quote]
D'oh! What was I thinking?? Brain fade there. You are of course right.
Post Posted: Sat Dec 04, 2010 7:12 am
:P
At least we didn't get into how a diff works thats always funny. :?
SS
Users browsing this forum: No registered users and 212 guests
