It is currently Wed Jul 29, 2026 11:03 pm
Post Posted: Sun Dec 05, 2010 9:51 am
I'm not 100% confident i understand the hole offset talk can some one lead me in the right direction. Thanks
Post Posted: Sun Dec 05, 2010 10:00 am
this one might help http://auszookers.com/index.php?name=Fo ... ght=offset
Post Posted: Sun Dec 05, 2010 10:11 am
depends on what lift you have to fit the tyres and how stable you want it offroad, low and wide is my motto, for 4by's that is not women.
Post Posted: Sun Dec 05, 2010 10:23 am
ive got a 2inch body lift atm
Post Posted: Sun Dec 05, 2010 11:22 am
Go with -13 on the rims. I'm running 3 inch suspension lift with 235/75/15 Muddies and they sit outside the guards around 1.5 inches. Looks mad and the wider stance is great offroad. Plus no rubbing or trimming needed.
Post Posted: Sun Dec 05, 2010 8:25 pm
How did u get -13 to clear the fire wall with out trimming
My car had 0 with 235 when I got it and it rubed a bit
Post Posted: Sun Dec 05, 2010 11:56 pm
I am currently running 235/75/15 Federal Couragia's on +3 offset 15x7" rims i only get a tiny bit of rubbing on the rear wheel are lip which could be fixed by hammering the lip over or bump-stop spacers. I have no lift and tyres stick about 10mm past the guards but not enough to noticeable need flares. You could probably still fit 30's on +3 rims but if you are planning a tyre any wider than that get the a bigger offset.
offset is essentially where the mounting face of the rim sits in respect to the centreline of the wheel
Post Posted: Mon Dec 06, 2010 12:01 am
I have -13 with 235 and just bashed the crap out of the wheel well / firewall on the front and 50mm bumpstop spacers on the rear
Post Posted: Mon Dec 06, 2010 12:02 am
what is the best for an offset then, how do you do it ad all that, im still a bit confused, sorry.
Post Posted: Mon Dec 06, 2010 12:40 am
the best for an offset will depend on how wide you want/need the track of your car to be and also depend on what tyre size you are looking at running. id say for anything a 30 or bigger you will probably want something with a negative offset.
Post Posted: Mon Dec 06, 2010 5:46 am
I run 31on +10 with some trimming bump stop spacers and widening mod and steering stops to stop rubbing on the chassis
There would be no way I could get 31 on the back with-rims without a 3in body lift
Post Posted: Mon Dec 06, 2010 6:04 am
well i only got a 2in bod lift and want to get some whell that i wont have major rub with . i would like a wide offset look mean and also as you said beter off road . what do you guys recommend?
Post Posted: Mon Dec 06, 2010 6:51 am
If you only have the 2 inch body lift I'd say go for a set of 235's they are a good size and don't affect gearing too much and put them on some -13 offset steelies for a wider stance. The body lift should mean no rubbing at this tyre size. Not sure how you would go with 30's and only the body lift without doing a bit of guard bashing.
Post Posted: Mon Dec 06, 2010 7:40 am
well im planning to do a 1.5in suspension sum time soon soo i can deal with abit of rub for the time being.
Post Posted: Mon Dec 06, 2010 7:53 am
if you are going the suspension lift as well then probably just go 30's straight up. I have no lift at the moment but will be doing a 2in lift start of next year. given you have the body lift that should give you enough clearance to run 30's worst case scenario you may need to extend bump stops or hammer over the seams in the front firewall
Post Posted: Mon Dec 06, 2010 8:19 am
so with the -13 how much of the wheel actuly sticks out of the standard gaurd? in mm
Post Posted: Mon Dec 06, 2010 8:22 am
the outside of the tyre id say would be about 40mm past the guards. you would want to have 50mm flare to cover it all. FullyZooked mentioned before that his stick about 1.5in with 235's and a 30 isnt much wider than that
Post Posted: Mon Dec 06, 2010 8:24 am
I have 50mm flexi flares and the tread is covered, bit of sidewall sticks out
Post Posted: Mon Dec 06, 2010 8:38 am
Mine are 15 x 7 rims, -13 offset with small 31's
Post Posted: Mon Dec 06, 2010 10:13 am
christover1 what sorta lift are ya running?
Post Posted: Mon Dec 06, 2010 10:23 am
50mm body lift, small coil spacers, Old Man Emu 40mm springs. firewall bashing and trimmings
Post Posted: Mon Dec 06, 2010 10:48 am
i run -18, sticks out about 50mm from the body. i didnt buy the rims as there where on the car when i go it, but i think they work really well. yeah they are wide and scrub a bit but the width and the look makes up for it.
i think the lower outer edge of the mud flap is where the out edge of the stock wheels would be, and mine is a good 2.5" wider.
Post Posted: Mon Dec 06, 2010 9:04 pm
shandy92 that looks mean.. but the only prob i have atm is that my girl is driving it as her daily so i gota keep it all neat and tidy and scrubless :P if ya no wat i mean. friken girls!!
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Tue Dec 07, 2010 5:50 am
soft eric just do it im sure she can put up with it till u get the lift, The sierra has started to scrub a little bit, but at the end of the day its just a 4b not a mercedes.
Post Posted: Tue Dec 07, 2010 7:36 am
thought it might . lol yeh ill sort sumthing out there jsut lookin at my options .
Post Posted: Tue Dec 07, 2010 9:42 am
ahaha cheers, havnt been called that yet. if they are a nice rim and tyre, neat flare job she might like driving it. my gf likes driving mine, except for the steering (non P/S), maybe ask her and see what she says.
Mitch
Post Posted: Wed Dec 08, 2010 4:18 am
yeh shes prty keen on the mini monster look , but wants it neat and i like it neat as well - jsut all comes down to the $$$$ i spend :P
Users browsing this forum: No registered users and 332 guests
