It is currently Fri Sep 25, 2026 5:53 am
Post Posted: Sat Jan 30, 2010 8:40 am
This is probably going to sound like the "Dumb & Dummer" show but I have a 1989 Short wheelbase soft top. engine No. G13A59.... Vin No. JSAOSJ50...I have been looking for odd bits and pieces on ebay and I'm confused (Which isn't hard at my age!) as to just what model it is...
1. Is it an SJ413?
2. Is it a wide track?
3. Is it an G13B motor?
Also I downloaded a manual for a Suzuki SJ Samurai which seems like the right one,...is it? and I have a SA413 manual are they the same motors????
Vehicle: jimny
Post Posted: Sat Jan 30, 2010 12:16 pm
it should be a sj70 i think which is a wide track. As for the engine it should be on the compliance plate. Just look near your engine number to see how many cc it is, also by the looks of your engine number it is a g13a. Im still pretty new to sierras so im happy to be corrected
Vehicle: Clown Car..
Post Posted: Sat Jan 30, 2010 12:48 pm
capacity is next to the timing mark on the passenger side, will be either 1298cc or 1324cc, both are '1.3litre'
SJ413.. correct..
the G13a59... screams its a g13a :lol:
the jsa0sj50.. would imply its an SJ50..
wt or nt it shouldnt matter.. easiest way is to look at where the spring perches are. The NT comes directly down from the chassis rail, while the WT are 'outboarded' about 2 inches..unless its been tinkered with..?
NT has small plastic guard flares while the WT has slightly larger steel(early had plastic) to account for the extra width of the wider diffs...
try a search for WT/NT difference or similar, its ALL listed there..
http://www.auszookers.com/index.php?nam ... difference
http://www.auszookers.com/index.php?nam ... pic&t=6138
oh and a pic will give the fellas some eye candy and a better idea as to what you got :)
Vehicle: jimny
Post Posted: Sat Jan 30, 2010 12:56 pm
well i didnt even read the vin, looks like it is a sj50 after all
Post Posted: Sat Jan 30, 2010 1:26 pm
Found on the compliance plate it's an SJ50 (Put my glasses on this time!) engine capacity 1324 cc. The spring mounts are set about 30 to 40 mm. to the outside of the chassis, not directly under the chassis rail. Sorry didn't see Trail Blazers photos! Yep thats the spring set up.
Post Posted: Sat Jan 30, 2010 1:28 pm
capacity imprint will look like one of these..
The front of an WT I had.. (spring location compared to chassis)-OUTBOARDED
The Spring location on a NT is as you can see.. inline with the chassis rail..
Wide track at the rear.. Note flares..
Standard NT flares
Post Posted: Sat Jan 30, 2010 1:29 pm
Makie43 wrote:
Found on the compliance plate it's an SJ50 (Put my glasses on this time!) engine capacity 1324 cc. The spring mounts are set about 30 to 40 mm. to the outside of the chassis, not directly under the chassis rail, so does that mean it's a wide track??
wide track tis...
Post Posted: Sat Jan 30, 2010 8:18 pm
Thanks all for your time and help...
Post Posted: Wed Dec 08, 2010 9:06 pm
This also sounds really stupid, but i would rather know than just be unsure. whats the difference between a samurai and a sierra. are they the same car or what...? thanks
Post Posted: Wed Dec 08, 2010 9:10 pm
sierra = aussie market
samurai = most other markets
its the same car.
Post Posted: Wed Dec 08, 2010 9:14 pm
okay i was thinking that but wasnt to sure, thanks heaps.
Users browsing this forum: No registered users and 120 guests
