It is currently Sat Oct 31, 2026 2:39 pm
Vehicle: 2018 DMAX
Post Posted: Wed Dec 08, 2010 6:54 am
As above looking to borrow a g16b coil/igniter for a few hours around brisbane. All i want to do is plug it in a see if my heap runs.. Offering some alcohol in return.
Cheers Jamie
Post Posted: Wed Dec 08, 2010 6:57 am
Yours is Denso yer??
Just so you don't get a Mitsubishi one...
Vehicle: 2018 DMAX
Post Posted: Wed Dec 08, 2010 6:59 am
Yer forgot to add that :) its a denso.
Post Posted: Wed Dec 08, 2010 9:53 am
Did you end up checking for injector pulses?
Lil Foot!
Post Posted: Wed Dec 08, 2010 9:57 am
I have a set of noid's here if needed...
Vehicle: 2018 DMAX
Post Posted: Wed Dec 08, 2010 10:13 am
Yer didnt check, no one i asked had noid lights.. Ill send you a PM dude
Post Posted: Wed Dec 08, 2010 9:45 pm
I have coil and igniter.
Post Posted: Wed Dec 08, 2010 11:30 pm
Well the other comp didnt work for ya so you have narrowed it down to, ignitor/coil, dizzy pickup or dodgy wiring. So get a noidie onto those injectors see if the comp is sending out any pulses while cranking. If not its very likely the dizzy pickup/wiring has issues and not the ignitor.
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Thu Dec 09, 2010 7:27 am
Ok its got no injector pulse. starting tracing wireing.. boost=money thanks for the offer.
Post Posted: Thu Dec 09, 2010 7:52 am
It's not something stupid like the tacho wire earthing??
Post Posted: Thu Dec 09, 2010 8:03 am
COuld be something like that. Also check the wires and connections out of the dissy as on these engines this is the only source of rpm and cam position to the ecu. Without it, no pulses to nuffin!
Lil Foot!
Post Posted: Thu Dec 09, 2010 8:05 am
:roll: This is going to end up in suzuki talk :lol: :lol:
Vehicle: 2018 DMAX
Post Posted: Thu Dec 09, 2010 8:53 am
Tacho what? i got a limiter for that. But its not earthing anywhere.
The two wires from the dizzy, from the plug near the dizzy to ecu has a circuit. The wires from that plug to dizzy seem fine.
The ecu earth is good.
The earth that runs to condenser/noise filter is good.
I have 12v+ at the BW to the coil
12v+ to the BW to the igniter
ive missed something i think
Post Posted: Thu Dec 09, 2010 9:01 am
are you getting pulse out of the dizzy??
Vehicle: 2018 DMAX
Post Posted: Thu Dec 09, 2010 9:15 am
You mean the two wires to the dizzy..
Does the ecu send a signal to the dizzy, that then comes back to the ecu?
Post Posted: Thu Dec 09, 2010 9:20 am
The dissy is the signal generator (magnetic reluctor). This is sent to the ECU.
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Thu Dec 09, 2010 9:37 am
Okay.. how would you test it?
I hooked one wire of the wires straight to earth, then the other to my test light, and the other end to positive. whice i figured would give me signal when i spun the dizzy but it didnt..
Post Posted: Thu Dec 09, 2010 9:42 am
Noooo!! Do you have a multimeter? You will need to check the resistance between the two wires out of the dizzy. Besides that the only other way is to again connect up the multimeter to the 2 dissy wires, crank teh engine and check for a fluctuating voltage. Should only be a couple of volts.
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Thu Dec 09, 2010 9:46 am
I tried it with the multimetetr earlier and there was nothing showing, voltage or resistance.
Post Posted: Thu Dec 09, 2010 10:07 am
Then thats your issue!! Try another dissy
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Fri Dec 10, 2010 6:27 am
Had a play with it today, and the dizzy is fine. The wire had a break in it.. So I fixed it and nothing changed. Im guessing the break happend sometime when ive been moving wires around to find the problem.
Post Posted: Mon Dec 13, 2010 11:01 pm
Ok so if your trace the wires back to the computer and measure the resistance there (comp unpluged) do you get the same reading as measuring straight from the dizzy?
Lil Foot!
Users browsing this forum: No registered users and 18 guests
