It is currently Fri Sep 25, 2026 4:09 pm
Post Posted: Fri Dec 10, 2010 8:14 am
hi every one just a few problems can you help???
1. when i put the brake on the symbol for high beams comes on in the dash and when its in parkers as well
2. When i put the low beems on it the light for high beams comes on again and other way around
3. when i put the righ blinker on it buzzers and only the back comes on
4. i got no parkers all round the car
5. ive got no dash lights
PLEASE HELP
!!I spend more money on oil than fuel!!
Post Posted: Fri Dec 10, 2010 8:18 am
3rd fuse on the top right side I think. Check it. Might look ok but replace and check again.
Seems to work for every other elect prob. :-)
bad earth near the head lights either side or blown fuse are my bet
Post Posted: Fri Dec 10, 2010 8:20 am
top row 3rd from the left fuse, but you will have to find what caused it to blow, last 2 time's mine did this the tyre had grabbed a harness & stretched it a lil to far, causing it to short on the body.
Unplug all light's, fit new fuse, plug light's back in one at a time till the fuse blow's, then you have found the area of the fault.. :P
Post Posted: Fri Dec 10, 2010 8:22 am
thanks for te help guys ill check in the mornin
umm doin you really need parkers in the front cause i never use them my lighht are either on or off?
Post Posted: Fri Dec 10, 2010 8:34 am
Yes.....
Post Posted: Fri Dec 10, 2010 8:58 am
rightho
Users browsing this forum: Google [Bot] and 110 guests
