It is currently Mon Nov 02, 2026 7:08 pm
Post Posted: Fri Dec 03, 2010 12:31 pm
basically just need the planatory gears so i can change my front diff to 26 spline, but whole diff would be better.
Post Posted: Fri Dec 03, 2010 7:44 pm
What ratio?
If your not breaking shit, try harder!!!
Post Posted: Fri Dec 03, 2010 7:54 pm
they are 4.1 ??? arnt they
Post Posted: Fri Dec 03, 2010 10:47 pm
pretty shore they are
dodgy brothers mechanical
Post Posted: Fri Dec 03, 2010 11:12 pm
4.1 - .2 = jimny ratio
Post Posted: Sat Dec 04, 2010 8:11 am
What axles are you going to run
Post Posted: Sat Dec 04, 2010 8:15 am
trial jimny said samuria front would fit if i used 26 slpine planatary gears so yea.
Post Posted: Sat Dec 04, 2010 8:17 am
I thought jimny diffs were wider?
Post Posted: Sat Dec 04, 2010 8:30 am
Bingo.
Post Posted: Sat Dec 04, 2010 9:45 am
That's why I asked have been down this track before only way I found round it was the 26 spline side gears v6 vitara cv's and some custom axles expensive seeing as I give mine a bit of shit and don't realy break that many have only done 1 axle and one cv 2 years unless you want to lock it then you will need the upgrade let me know if you find a cheaper way I would like to do mine if it's not to expensive.
Post Posted: Sat Dec 04, 2010 2:14 pm
yea i think its either samuria or wide track that will fit. will have to look into it more and ill let u know
Post Posted: Thu Dec 09, 2010 8:01 pm
To be pedantic, diff ratio is 4.09:1
Some wreckers may get confused if you say 4.1
Post Posted: Fri Dec 10, 2010 9:35 am
To be pedantic,........
And while we're in that mood, Planetary Gears aren't found in diffs (well, OK they are in a Torsen-Gleason LSD, but we're not talking about that). They are most commonly found in Auto Transmissions and winches, but also as the Low reduction in Coily and Jimny transfer cases.
The 2 lots of gears within a diff are the spider and side gears, or the crown wheel and pinion gears. These also go by other names as well, but never Planetary gears.
Post Posted: Fri Dec 10, 2010 1:42 pm
cheers mr technical, i was just told to ask for planatory gears out of the rear of a jimny, thats what trial jimny said
Users browsing this forum: Google [Bot] and 9 guests
