It is currently Fri Nov 06, 2026 6:04 am
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Fri Dec 17, 2010 6:09 am
hi there need to borrow a clutch aligning tool for the sierra all the ones i've come across from mates or family to borrow have been too large to fit into the back of the engine
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Fri Dec 17, 2010 6:13 am
Do it by eye Mate. Has worked every time Royce has done mine.
Post Posted: Fri Dec 17, 2010 6:15 am
I normally line em up by eye..
If you have an ole g/box laying round you can pull the input shaft out & use that....
Yeah but with his short legs he's at the perfect height to do it. :P
:lol:
good point i could give it a try, i've never done a manual before, i guess just try and make it central?
edit: yeah wouldn't mind a spare input shaft
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Fri Dec 17, 2010 6:16 am
Bwhahahahahahahahahahahahaha
Love it Peter.
He is a little hobbit :wink:
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Fri Dec 17, 2010 6:32 am
I used a combo of sockets and screwdrivers from memory
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Fri Dec 17, 2010 6:43 am
how did this work?
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Fri Dec 17, 2010 7:06 am
youve only got to get it in the middle, look down the hole with one eye and first look at the splines, if they look even your eye is in the middle, then look at the machining of the spigot hole, if the rings are central to the splines your in
If you were in Redcliffe QLD i'd pop over and do it for you :)
Post Posted: Fri Dec 17, 2010 8:36 am
well this redcliffe's right near the domestic airport, so you can still pop over, in a few hours or more lol
89 Sierra (Crashed)
95 Vitara (Current)
Vehicle: Clown Car..
Post Posted: Fri Dec 17, 2010 8:38 am
these work well n wont break the bank... http://www.supercheapauto.com.au/online ... 85#details
Post Posted: Fri Dec 17, 2010 8:40 am
dang just missed supercheap by 30 minutes, looks like that's the ticket will have to grab one tomorrow
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Fri Dec 17, 2010 8:52 am
dude just do it by eye and feel. line the hole up in the middle. then feel the gaps around the pressure plate should be even on all sides. theres three maybe four spots you can check on the pressure plate. you should be able to feel that the clutch disk is equal at all gaps. hope this makes sense. it does to me :lol:
Post Posted: Fri Dec 17, 2010 9:13 am
If you really must use an allignment tool, just use a bolt, round bar, or something round that's the size of the spigot bearing. Then just wrap tape around it in the right spot to the thickness of the spline of the clutch plate.
Instant allignment tool.
Post Posted: Fri Dec 17, 2010 10:44 am
i just saw this same idea on a car show, might try that first then
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Wed Dec 22, 2010 3:36 pm
tried a few of the home remedy's but failed, ended up with the supercheap item, gotta re hire a crane before i can get the engine in again, so we shall see if it works, when i can afford the crane again,
cheers for all the help guys
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Thu Dec 23, 2010 12:18 am
Ha ha...this thread brings back memories, I remember about 25years ago this old fella used to live in that strange old house that is straight ahead of you when you come to the top of Coopers Camp Road Bardon (up from your old place Steaky ) he used to work on cars at that old house, his name was Barry. Anyway I was there one day and he had a square cake tin with all these clutch aligning tools for different cars, he had turned them down out of hardwood on this little old wood lathe and they had the car written on them with a niko pen.
Post Posted: Thu Dec 23, 2010 12:23 am
well this clutch aligning tool from supercheap is shit, i've tried like 5 times now and still doesn't work, i followed both sets of instructions even, i tried the other listed methods they don't work either, i've had to hire a second crane to try this again, and i'm just running out of money and need my car back,
can anyone tell me a SURE FIRE way to get this bloody engine to my gearbox, this is beyond frustrating, it shouldn't be this hard especially when i bothered to buy the bloody tool for the job
*sigh*
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Thu Dec 23, 2010 12:28 am
Post Posted: Thu Dec 23, 2010 12:40 am
yeah i've tried that, i dunno if i just have bad judgement or something, i even tried to match the gap around the edges,
am i doing something wrong when it meets the gearbox? i get the two studs lined in the holes on the block, but then it just gets stuck in the middle, i assume it's the clutch plate?
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Thu Dec 23, 2010 12:44 am
they dont jsut slide together, you need to sometimes turn the motor a bit to line the slines up (gearbox in gear) and give it a good shove
Post Posted: Thu Dec 23, 2010 12:47 am
you could also put the gear box in gear and slide the jack shaft in the back. turn it to help the splines mesh??
Post Posted: Thu Dec 23, 2010 12:54 am
i've put the gearbox in neutral hoping the shaft would turn itself
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Thu Dec 23, 2010 12:58 am
I have had to either twist the gearbox or turn the shaft to line them up before. i doubt it would turn itself
Post Posted: Thu Dec 23, 2010 1:00 am
ok i'll try that too
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Thu Dec 23, 2010 2:11 am
Some boxes can take a lot of wrestling to get in. I found it easier to have the gearbox floating, mount the engine properly, then get under and shove the box back on. Try the box in gear with the shaft in and turn till you feel it engage in the spline. Then just push and wiggle.
Vehicle: LWB Vitara
Post Posted: Thu Dec 23, 2010 3:07 am
you can get vehicle specific aligning tools for next to nothing. I got mine for my sierra for like $8. Just a plastic cheapie but it works fine. The gearbox still takes a while to line up properly though.
Post Posted: Thu Dec 23, 2010 9:06 am
Make sure the clutch you got is the right spline number aswell
My Maruti build, Click WWW
Post Posted: Thu Dec 23, 2010 9:16 am
:lol: :lol: I remember him!!! :lol:
He used to put shake proof washer's on the vale's to "spin" the air as it goes into the head, I think he invented the hyclone.. :lol: :lol:
Users browsing this forum: No registered users and 21 guests
