It is currently Thu Jul 30, 2026 7:04 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Mon Dec 13, 2010 12:20 am
Has anybody on here done this conversion and if so is there much to it? I have access to hoist etc so the labour part of the job is no issue.
Cheers Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Mon Dec 13, 2010 1:02 am
rusho(maybe soon), saam, jonno, many times before, have a quick look
Post Posted: Mon Dec 13, 2010 1:21 am
I did it to my coily, used a WT transfer case, WT transfer mounts, WT jackshaft. You
will have to use the WT tailshaft (front/rear/jackshaft) nuts and bolts as the coily transfer case has a thread taped into each flange. Takes about 40mins to do if that!
Post Posted: Mon Dec 13, 2010 1:33 am
^^^^^ get new bolts and nilocks m10x35mm
Post Posted: Mon Dec 13, 2010 1:59 am
Also, I wouldn't bother putting one in unless it's got reduction gears fitted or the coily one is toast. No real
gain other than allowing you to fit gears.
Post Posted: Mon Dec 13, 2010 3:22 am
yeah cheers for that was planning on fitting some reduction gears to it before fitting.
Post Posted: Mon Dec 13, 2010 3:58 am
i just realised the transfer case i got is out of a n/t, does this make a difference??
Post Posted: Mon Dec 13, 2010 3:59 am
yeah, the flanges that the shafts bolt to are different
Post Posted: Mon Dec 13, 2010 7:09 am
Can the coily flanges be fitted to the nt transfer??
Post Posted: Mon Dec 13, 2010 7:43 am
I'm glad you asked that question...I would like to know the answer to that also :P
Vehicle: SJ80
Post Posted: Mon Dec 13, 2010 7:55 am
Rusho, Richo, I'm almost certain they are different.
Post Posted: Mon Dec 13, 2010 8:23 am
there diffrent.
Post Posted: Mon Dec 13, 2010 8:26 am
Damn you two :evil:
Post Posted: Mon Dec 13, 2010 10:57 am
The Coily has Hi:1.320 and Low:2.145 ratios, so putting in a stock 1.3 geared case will give him 1.409/2.268, or a stock 1.0 case will give him 1.580/2.511.
High range reductions for his Coily would be 6.7% for the 1.3case, or 19.6% for the 1.0 case. Not to be sneezed at, and then there's reduction gears to go further if he wants.
Post Posted: Mon Dec 13, 2010 11:50 am
either way the transfer i've got is out of an nt not a wt so it's useless to me anyway as the flanges are different.
Post Posted: Mon Dec 13, 2010 12:00 pm
Just swap the flanges over mate. Thats all you need to do. Put a wanted ad up for WT transfer flanges. :wink:
Post Posted: Mon Dec 13, 2010 12:12 pm
Or you could keep those flanges on it, and put up an ad for NT driveshafts, 'cos you're going to need whole a new jackshaft anyway.
Post Posted: Mon Dec 13, 2010 12:14 pm
Or that :lol:
Post Posted: Mon Dec 13, 2010 12:46 pm
Or that :lol:
What about the diff flanges? :?
Post Posted: Mon Dec 13, 2010 1:03 pm
Half and half shafts. Coily on the Diff ends and WT or NT on the Transfer ends.
Post Posted: Mon Dec 13, 2010 6:17 pm
Not exactly the cheapest away to do it, or the easiest
Post Posted: Mon Dec 13, 2010 10:46 pm
Iv'e got the NT jackshaft and might be able to get the driveshafts so thats an idea i can think about, cheers for the input
Richo
Post Posted: Tue Dec 21, 2010 2:01 am
picked up a NT 1lt transfer with mounts and jackshaft and both driveshafts for $150 so i'm gonna have a crack at the conversion this week without reduction gears to see how big a difference it makes to my coily. I'm currently running 30" stt's so hopefully it gives some better low range!
Post Posted: Tue Dec 21, 2010 2:06 am
Its not going to be that much of a reduction really is it :? Still better than a coily POS t'fer though :P
Reduction gears to follow??
Vehicle: SJ80
Post Posted: Tue Dec 21, 2010 2:40 am
Rusho wrote:
Its not going to be that much of a reduction really is it !
Good luck with the conversion Richo.
Rusho, I reckon you'd be very surprised at the difference. Mine has 30"s, and with the 1L case it makes a huge difference. :)
In anycase even if you're after more gearing, $150 isn't a bad spend for an immediate improvement. Especially considering that for gears you need to do the conversion anyway 8)
Post Posted: Tue Dec 21, 2010 4:10 am
If they are the same as a 1L transfer. Just do as i did.
Take the original flanges and cut a section of about 5-10mm (can't remember exact amount) of the splined section off, this becomes a spacer. Slip it onto the output shaft, then slip the coily flanges on. It will space them out enough so they don't foul on the case body.
Vehicle: SJ80
Post Posted: Tue Dec 21, 2010 4:23 am
from memory the spline count / shaft diameter was different.
Post Posted: Tue Dec 21, 2010 8:19 am
Just sell the NT case and buy a donor WT for the reduction gears... I picked mine up for $90, you could get atleast half that
for the NT case.
Post Posted: Tue Dec 21, 2010 10:42 pm
for the NT case.
WT t/fers are like rocking horse shit in WA and when you do find em they sure aint $90 and why would i just sell a NT case for $45 when i just paid $150 for it :?:
Post Posted: Wed Dec 22, 2010 7:54 am
Richo wrote:
for the NT case.
X2. keep the NT case and slap some gears in it. Worry about the flanges later :wink:
Users browsing this forum: Google [Bot] and 256 guests
