It is currently Thu Jul 30, 2026 2:22 am
Post Posted: Mon Dec 27, 2010 9:05 am
Hey guys i got a new battery recently and now i have the problem of every time i start my car its fine, but as soon as i turn on the lights the fuse for the radio, clock and dashboard lights blows. Any ideas how to fix? Its werid because the headlight fuses are fine and so is the external amp for the speakers.
96 coily Sierra SWB
Post Posted: Mon Dec 27, 2010 9:08 am
did you fit a stereo at the same time?
Post Posted: Mon Dec 27, 2010 9:15 am
Pull the stereo out, cut the earth wire off where it was connected to the loom and attach it to the nearest metal surface in behind. Job done.
Post Posted: Mon Dec 27, 2010 9:17 am
Your not just a pretty face are you :finger:
Post Posted: Mon Dec 27, 2010 9:20 am
Rusho wrote:
Your not even a pretty face are you :finger:
Fixed :wink:
Post Posted: Mon Dec 27, 2010 9:22 am
ScrawnC wrote:
Fixed :wink:
:rofl: :rofl: :rofl: Lights out you might be ok :P
Post Posted: Mon Dec 27, 2010 9:26 am
Na, not even then
Post Posted: Mon Dec 27, 2010 9:43 am
ScrawnC wrote:
Na, not even then
On the plus side you wouldn't be able to tell you're a ranga with the lights out :lol:
It must the wet weather because I noticed a couple of electrical gremlins in the last couple of days. Yesterday I was driving home from work and the engine went dead for a few seconds, then came back to life. I'm guessing ignition went dead. Then today I noticed that the windscreen wipers wouldn't turn off until I turned the headlights off.
I had the dash out recently but up til now everything has been A-OK. I'm thinking there must be a dodgy earth somewhere that the rain has made worse :cry:
Post Posted: Mon Dec 27, 2010 9:56 am
Don't you hate annoying problems like that
Post Posted: Mon Dec 27, 2010 11:52 am
Thanks guys i shall redo it in the morning. and no didnt install a new radio.
Post Posted: Mon Dec 27, 2010 8:07 pm
then its something else, look for a squished taillight or parker wire somewhere
Post Posted: Tue Dec 28, 2010 8:43 am
Alright because the radio and amp was in before i changed battery, but now that the battery has been changed it keeps blowing? I haven't been able to redo the ground but i will do soon anything else i should check when i do the ground? and any idea what color it is.
Post Posted: Tue Dec 28, 2010 5:39 pm
As Royce suggested, check your tail light wiring for a crushed wire (shorting out) somewhere.
Vehicle: SJ80, SE416
Post Posted: Wed Dec 29, 2010 1:13 am
X2... I see you have a coily...
In a coily, the brake proportioning valve arm/spring assembly is directly beneath the loom on the underside of the floor - if your coily has been riding it's bumpstops for a while the arm on top of the axle for the proportioning valve can cut into the loom and cause a short. Had that happen once and it isn't too hard to repair - more a pain in the butt having to add 100mm to the loom to run it off to the side a bit.
Post Posted: Wed Dec 29, 2010 1:39 am
oh god haha i just wanted to listen to music... and have lights that work. in that order haha
Post Posted: Thu Dec 30, 2010 9:29 am
LOL... i had a problem with the Head Unit Dimmer Wire in my last 4by. Check it hasn't been mistakenly connected to earth or isn't touching any metal bits :)
Stocker
Post Posted: Fri Dec 31, 2010 11:27 pm
Okay i swear i will look at it today! Those beers wont get the better of me today haha
Users browsing this forum: Google [Bot] and 698 guests
